[ZOO-Discuss] GIS GRASS ZOO integration
Eugenio Realini eugenio.realini at gmail.com
Wed Oct 6 20:19:10 PDT 2010
Hi Soeren, hi Luca,
this is our situation now:
1) we have re-generated the WPS.1.0.0 python modules with PyXB 1.1.1,
this solved the problems we had with it
2) we faced the Xerces issue Soeren was talking about, so we
recompiled GDAL with it and also this was solved
3) launching "python ZOOGrassModuleStarter.py" does not give any error
4) launching "r_univar" through ZOO gives us this exception:
<ows:ExceptionText>
TRACE : invalid literal for int() with base 10: 'NULL'
TRACE : <type 'exceptions.ValueError'>
Unable to run your python process properly. Please check the following
messages : ['  File "/usr/lib/cgi-bin/r_univar.py", line 4, in
r_univar\n    service.fromMaps("r.univar", inputs, outputs)\n', '
File "/usr/lib/cgi-bin/ZOO_Project/ZOOGrassModuleStarter.py", line
110, in fromMaps\n    self._createInputOutputMaps()\n', '  File
"/usr/lib/cgi-bin/ZOO_Project/GrassModuleStarter.py", line 214, in
_createInputOutputMaps\n    self._checkBandNumber()\n', '  File
"/usr/lib/cgi-bin/ZOO_Project/GrassModuleStarter.py", line 331, in
_checkBandNumber\n    self.bandNumber = int(self.inputMap[i])\n']
</ows:ExceptionText>
To my understanding, it does not like getting 'NULL' as
'grass_band_number', since it expects an integer.
You can read the contents of the logfile here: http://pastebin.com/pxG1VVaz
This is the link to the r_univar execute request:
http://131.175.143.108/cgi-bin/zoo_loader.cgi?Service=WPS&Request=Execute&Version=1.0.0&Identifier=r_univar&DataInputs=map=DTM_108.tif
Any idea on how to proceed from here?
Thanks!
Eugenio
2010/10/4 Luca Delucchi <lucadeluge at gmail.com>:
> 2010/9/29 Soeren Gebbert <soerengebbert at googlemail.com>:
>> Hello Eugenio,
> hi soeren and eugenio
>>> Still not working also with PyXB 1.1.1
>> Well this is strange ... .
> with PyXB 1.1.1 I also have an error but is different from the eugenio one...
>>>> import WPS_1_0_0.OGC_WPS_1_0_0 as wps
> Traceback (most recent call last):
>  File "<stdin>", line 1, in <module>
>  File "/usr/lib/cgi-bin/WPS_1_0_0/OGC_WPS_1_0_0.py", line 132, in <module>
>    Namespace.addCategoryObject('typeBinding', u'DataType', DataType)
>  File "/usr/local/lib/python2.6/dist-packages/pyxb/namespace/__init__.py",
> line 330, in addCategoryObject
>    raise pyxb.NamespaceUniquenessError(self, '%s: name %s used for
> multiple values in %s' % (self, local_name, category))
> pyxb.exceptions_.NamespaceUniquenessError:
> http://www.opengis.net/wps/1.0.0: name DataType used for multiple
> values in typeBinding
>>> Since the error is in _ows.py, that I've seen it was generated by
>>> PyXB, could I try to generate it again from scratch?
>> Yes you can try to generate the WPS.1.0.0 python modules with PyXB
>> 1.1.2 by yourself:
>> mkdir WPS_1_0_0
>> cd WPS_1_0_0/
>> pyxbgen -u http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd -m OGC_WPS_1_0_0
>> touch __init__.py
>> Then replace the WPS_1_0_0 dir with the new one.
> I tried also this but I have the same problem...
>> I hope you are able to run it. Please use the latest svn version of
>> the wps-grass-bridge, i fixed some bugs.
> i update my svn to today
>> Best regards
>> Soeren
> thanks and regard
> Luca
More information about the Zoo-discuss mailing list
