[ZOO-Discuss] [ZOO Project Trac] #20: Install pdftex on ZOO server
ZOO Project Trac zoo-dev at cartography.st
Sat Apr 16 12:03:40 PDT 2011
  Reporter:  jmckenna              |       Owner:
      Type:  task                  |      Status:  new
  Priority:  major                 |   Milestone:
 Component:  Development platform  |     Version:
Resolution:                        |    Keywords:
Comment (by djay):
 Replying to [ticket:20 jmckenna]:
 >  - I need the pdflatex utility (through pdftex) for the docs
 >  - I tried to install pdftex on server through emerge
 >  - compile fails while trying to build libpoppler
 ("../libpoppler.so.7.0.0: undefined reference to `png_set_longjmp_fn'"
 The install from emerge works ok now. I didn't look deeper but it seems
 that poppler package use /usr/local/lib as default search path for
 libpng12.so, the trouble came from an older version installed in this
 directory.
 >  - my guess is that libpoppler is linking to an old libpng (1.2 instead
 of 1.4)
 You guess well, it tried tolink against libpng12.so file in
 /usr/local/lib.
 > Gerald can you give me a hand on this, or should I compile from source?
 Done, hope the tool is correctly usable now.
Ticket URL: <http://svn.zoo-project.org/trac/ticket/20#comment:2>
ZOO Project Trac <http://www.zoo-project.org/>
Open WPS Platform
More information about the Zoo-discuss mailing list
