[ZOO-Discuss] Error when running GRASS processes
Gérald Fenoy gerald.fenoy at geolabs.fr
Thu Apr 28 05:13:09 PDT 2011
Hi Pierre,
Nice to hear from you.
First of all, some times ago we've tested the GRASS Services you are trying to use on your computer so I can confirm your tests should succeed.
As the message coming back from the ZOO-Kernel in this case is not verbose enough, I suggest to try the same request you're using from the command line to see more details displayed. Another way to get more information about the reason why the ZOO-Kernel can't load the GRASS Service would be to take a look at the Apache error log and check if there is more details here. Using tail -f apache_error.log should be goos as you can see only informations relative to your current Service.
I'm pretty sure this will give you enough informations about the issue whicj happened. Please, give us this detailled informations and I'm surewe can help.
Waiting for your answer,
Best regards,
Gérald Fenoy
ZOO-Project dev team member
Le 28 avr. 2011 à 02:58, Pierre Roudier <pierre.roudier at gmail.com> a écrit :
> Dear zoo-keepers,
> I'm trying the WPS GRASS bridge - unfortunately I can't make it work so far.
> I've added two GRASS  processes to my /usr/lib/cgi-bin:
> root at grass:/usr/local/src/zoo/zoo-kernel# ls /usr/lib/cgi-bin/ | grep .zcfg
> HelloPy.zcfg
> v_delaunay.zcfg
> v_voronoi.zcfg
> The GetCapabilities is working fine. In QGIS, I'm using the WPS plugin
> to try to make a Voronoi tesselation or a Delaunay triangulation of a
> dummy points shapefile. In both cases, I got the following error when
> running the process:
> <?xml version="1.0" encoding="utf-8"?>
> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xsi:schemaLocation="http://www.opengis.net/ows/1.1
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="en-US" version="1.1.0">
>  <ows:Exception exceptionCode="NoApplicableCode">
>    <ows:ExceptionText>Python module v_delaunay cannot be loaded.
> </ows:ExceptionText>
>  </ows:Exception>
> </ows:ExceptionReport>
> Any suggestion?
> Cheers,
> Pierre
> Scientist
> Landcare Research, New Zealand
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110428/b593a974/attachment.html>
More information about the Zoo-discuss mailing list
