[ZOO-Discuss] configure option "--with-python" went wrong
Gérald Fenoy gerald.fenoy at geolabs.fr
Thu Apr 28 04:42:07 PDT 2011
Hi Elvis,
Nice to hear from you.
You used the right command to configure ZOO-Kernel, using ./configure only, as you mentioned should work. So, I would like to ask you some more details about the source code you used to compile the ZOO-Project on your platform.
First of all, can I know where the source code you are trying to compile is coming from ? In other terms, can you confirm that you are using the lastest SVN source tree ? Indeed, the python support is now disactivated per default and I'm pretty sure this is ok.
Second question, in case you are using the SVN source tree, can you confirm that you are using an updated version of the SVN source tree ? Indeed, as for each supported languages, in the current SVN sources the PHP supportis deactivated per default so this error should not occur.
Hope you can answer to this mail and you can compile ZOO-Kernel on your platform,
Best regards,
Gérald Fenoy
ZOO-Project dev team member
Le 28 avr. 2011 à 11:05, "Elvis Wang" <wbprime at gmail.com> a écrit :
> Hi all,
> I tried to compile the ZOO kernel in my Arch linux X64 platform. In fact I don't want to enable the python support. So I just run ./configure using bash. But after configuring, there came an error that shows "configure: error: could not find python-config from libpython within the current path. You may need to try re-running configure with a --with-python parameter."
> So I had to give the with-python option. I changed the configure file to find the python2-config file in my system in /usr/bin for I Arch installed python2.7 as default. It solved the problem by running "./configure --with-python=/usr". But another problem is that "configure: error: the user-specified php-config file /bin/php-config does not exist". I had not installed PHP and I did't want to install it. What should I do to compile zoo  kernel directly?
> Thanks in advance.
> ELvis Wang
> By Elvis Wang from Beijing, China. E-mail: wbprime at gmail.com
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110428/abf37c98/attachment.html>
More information about the Zoo-discuss mailing list
