[ZOO-Discuss] Error when running GRASS processes
Soeren Gebbert soerengebbert at googlemail.com
Thu Apr 28 23:42:24 PDT 2011
Hello Pierre,
2011/4/29 Pierre Roudier <pierre.roudier at gmail.com>:
> Thanks Soeren,
>> The zoo services v_voronoi.py and v_delaunay.py must be present in
>> /usr/lib/cgi-bin/ too.
>> The minimum content of this directory should be:
>> gms  main.cfg  v_delaunay.py  v_delaunay.zcfg  v_voronoi.py
>> v_voronoi.zcfg  ZOOGrassModuleStarter.py  zoo_loader.cgi
> Corrected that.
> However, It still throws an error. Here's the apache log:
> Traceback (most recent call last):
>  File "/usr/lib/cgi-bin/v_voronoi.py", line 4, in <module>
>    import ZOOGrassModuleStarter as zoo
>  File "/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 24, in <module>
>    import GlobalGrassSettings
> ImportError: No module named GlobalGrassSettings
> error : file not found
Sorry my fault!
The file GlobalGrassSettings.py must be present within this directory
too. Additionally you must edit this file to set the paths to your
GRASS GIS 7 installation and to the logfiles. The logfiles must be set
writable for you webserver.
>> Yes, it is designed to run from the shell i.e:
>> cd wps-grass-bridge/Testing/Python
>> python SendRequests.py -f ExecuteRequests/v.voronoi.execute.xml -u
>> "http://localhost/cgi-bin/zoo_loader.cgi"
> Here's the error on the execution of that request:
> root at grass:/usr/local/src/wps-grass-bridge-read-only/Testing/Python#
> Start request 0
> ########### 0 ##########
> <?xml version="1.0" encoding="utf-8"?>
> <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xsi:schemaLocation="http://www.opengis.net/ows/1.1
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="en-US" version="1.1.0">
>  <ows:Exception exceptionCode="InvalidParameterValue">
>    <ows:ExceptionText>The value for <indetifier> seems to be
> wrong (v.voronoi). Please, ensure that the process exist using the
> GetCapabilities request.</ows:ExceptionText>
>  </ows:Exception>
> </ows:ExceptionReport>
This is an unexpected error ... i don't know why this is not working
with ZOO WPS??? I am using a POST request to deliver the XML content,
maybe Gerald can clarify this issue?
Best regards
Soeren
> Cheers,
> Pierre
>> Best regards
>> Soeren
>>> Your help, and the efforts you are putting on open-source software,
>>> is greatly appreciated.
>>> Best,
>>> Pierre
>>>> Best regards
>>>> Soeren
>>>> 2011/4/28 Pierre Roudier <pierre.roudier at gmail.com>:
>>>>> Dear zoo-keepers,
>>>>> I'm trying the WPS GRASS bridge - unfortunately I can't make it work so far.
>>>>> I've added two GRASS  processes to my /usr/lib/cgi-bin:
>>>>> root at grass:/usr/local/src/zoo/zoo-kernel# ls /usr/lib/cgi-bin/ | grep .zcfg
>>>>> HelloPy.zcfg
>>>>> v_delaunay.zcfg
>>>>> v_voronoi.zcfg
>>>>> The GetCapabilities is working fine. In QGIS, I'm using the WPS plugin
>>>>> to try to make a Voronoi tesselation or a Delaunay triangulation of a
>>>>> dummy points shapefile. In both cases, I got the following error when
>>>>> running the process:
>>>>>  <ows:Exception exceptionCode="NoApplicableCode">
>>>>>    <ows:ExceptionText>Python module v_delaunay cannot be loaded.
>>>>>  </ows:Exception>
>>>>> Any suggestion?
>>>>> Cheers,
>>>>> Pierre
>>>>> Scientist
>>>>> Landcare Research, New Zealand
>>>>> _______________________________________________
>>>>> Zoo-discuss mailing list
>>>>> Zoo-discuss at gisws.media.osaka-cu.ac.jp
>>>>> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>>> Scientist
> Scientist
More information about the Zoo-discuss mailing list
