[ZOO-Discuss] Error when running GRASS processes
Luca Delucchi lucadeluge at gmail.com
Fri Apr 29 05:31:21 PDT 2011
2011/4/29 Soeren Gebbert <soerengebbert at googlemail.com>:
> Is this error raster data related? What process are you running.
I tried another module r_random_cells and I have another problem; I
think this is related to ZOO
this is the log of WPS client plugin of QGIS
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xlink="http://www.w3.org/1999/xlink"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
xml:lang="en-US" version="1.1.0">
  <ows:Exception exceptionCode="InternalError">
    <ows:ExceptionText>ZOO Kernel failed to process your request
receiving signal 11 = SIGSEGV</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
because the log of wps bridge it seam ok
logfile.txt
[CUT]
Checking GDAL data type and nodata value...
 100%
WARNING: Unable to set projection
Exporting raster data to GTiff format...
 100%
r.out.gdal complete. File </var/www/zoograss/tmp/tmp4QGMA4/output_0>
created.
</INFO>
<INFO timestamp="14:24:47">
Attached output file /var/www/zoograss/tmp/tmp4QGMA4/output_0
</INFO>
[CUT]
and logfile_module_sterr.txt
Generating raster map <output>...
 100%
Writing raster map <output>...
 100%
r.random.cells complete.
> Best regards
> Soeren
cheers
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss mailing list
