[ZOO-Discuss] Boundary ZOO Service
truongxuan quang truongxuanquang at yahoo.com
Fri Feb 11 07:08:03 PST 2011
Dear Gérald
Many thanks for your support.
I have followed your commands, the 1st and 2nd are fine,
root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# export
CFLAGS="`gdal-config --cflags` `xml2-config --clfags` -I../../zoo-kernel/"
LDFLAGS="`gdal-config --libs` `xml2-config --libs`
../../zoo-kernel/service_internal.o"
root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# gcc $CFLAGS
-shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
I got inform  bellow
gcc: Usage:: No such file or directory
gcc: xml2-config: No such file or directory
gcc: [OPTION]: No such file or directory
gcc: Known: No such file or directory
gcc: values: No such file or directory
gcc: for: No such file or directory
gcc: OPTION: No such file or directory
gcc: are:: No such file or directory
gcc: change: No such file or directory
gcc: libxml: No such file or directory
gcc: prefix: No such file or directory
gcc: [default: No such file or directory
gcc: /usr]: No such file or directory
gcc: exec: No such file or directory
gcc: print: No such file or directory
gcc: library: No such file or directory
gcc: linking: No such file or directory
gcc: information: No such file or directory
gcc: add: No such file or directory
gcc: to: No such file or directory
gcc: static: No such file or directory
gcc: pre-processor: No such file or directory
gcc: and: No such file or directory
gcc: compiler: No such file or directory
gcc: flags: No such file or directory
gcc: module: No such file or directory
gcc: support: No such file or directory
gcc: enabled: No such file or directory
gcc: display: No such file or directory
gcc: this: No such file or directory
gcc: help: No such file or directory
gcc: exit: No such file or directory
gcc: output: No such file or directory
gcc: version: No such file or directory
I checked, there are not exist  : xml2-config and gdal-config in /usr/local/bin
for example, I dont know where is the place to configure the libxml and gdal in
this case, I used OSGeo/live.
Thanks
T.X.Quang
To: truongxuan quang <truongxuanquang at yahoo.com>
Cc: zoo-discuss at gisws.media.osaka-cu.ac.jp
Sent: Fri, February 11, 2011 1:10:51 PM
Subject: Re: [ZOO-Discuss] Boundary ZOO Service
Dear Quang,
Please, try the following command  :
export CFLAGS="`gdal-config --cflags` `xml2-config --clfags`
export LDFLAGS="`gdal-config --libs` `xml2-config --libs`
gcc $CFLAGS -shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
It should work this way.
I noticed that you tried to set values to CFLAGS and LDFLAGS on one command
line. You have to first define the env variables then use them.
You asked about service_internal.o, it is present in your LDFLAGS so should be
found. This file is located in the zoo-kernel directory.
Hope this help,
Best,
Le 11 févr. 2011 à 12:02, truongxuan quang a écrit :
Hello Gérald
>Thank you for your email, and I also sorry for replying late.
>Bellow is my values set for both CFLAGS and LDFLAGS, because I am not familiar
>with Linux that why I have stuck in this section.
>root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# g++
>$CFLAGS=`gdal-config --cflags` `xml2-config --clfags` -I../../zoo-kernel/
>-shared -fpic -o cgi-env/ServicesProvider.zo ./service.c $LDFLAGS=`gdal-config
>--libs` `xml2-config --libs` ../../zoo-kernel/service_internal.o
>I got
>g++: =-I/usr/include/gdal: No such file or directory
>g++: Usage:: No such file or directory
>g++: xml2-config: No such file or directory
>g++: [OPTION]: No such file or directory
>g++: Known: No such file or directory
>g++: values: No such file or directory
>g++: for: No such file or directory
>g++: OPTION: No such file or directory
>g++: are:: No such file or directory
>g++: change: No such file or directory
>g++: libxml: No such file or directory
>g++: prefix: No such file or directory
>g++: [default: No such file or directory
>g++: /usr]: No such file or directory
>g++: exec: No such file or directory
>g++: print: No such file or directory
>g++: library: No such file or directory
>g++: linking: No such file or directory
>g++: information: No such file or directory
>g++: add: No such file or directory
>g++: to: No such file or directory
>g++: static: No such file or directory
>g++: pre-processor: No such file or directory
>g++: and: No such file or directory
>g++: compiler: No such file or directory
>g++: flags: No such file or directory
>g++: module: No such file or directory
>g++: support: No such file or directory
>g++: enabled: No such file or directory
>g++: display: No such file or directory
>g++: this: No such file or directory
>g++: help: No such file or directory
>g++: exit: No such file or directory
>g++: output: No such file or directory
>g++: version: No such file or directory
>g++: =-L/usr/lib: No such file or directory
>g++: ../../zoo-kernel/service_internal.o: No such file or directory
>Usage: g++ [options] file...
> One more question is how to get service_internal.o  file ?
>Thank you
>Quang
Gérald Fenoy
gerald.fenoy at geolabs.fr
GEOLABS
Siège social :
Futur Building I
1280, avenue des Platanes
34970 Lattes
Tél. fixe : +33 (0) 4 67 43 09 95
Tél. portable : +33 (0) 6 70 08 25 39
____________________________________________________________________________________
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
http://tools.search.yahoo.com/toolbar/features/mail/
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110211/7e08e198/attachment.html>
More information about the Zoo-discuss mailing list
