[ZOO-Discuss] Boundary ZOO Service
    Gérald Fenoy
    gerald.fenoy at geolabs.fr
    Fri Feb 11 08:36:32 PST 2011
Dear Quang,
scuse me, at the beginning you used g++ so I didn't noticed that after you changed for
g++. It seems you need to use g++ in your case.
Your service provider is depending on CGAL. Are you sure you get it installed on your
OSGeoLiveDVD platform ?
If not, you probably would use the following command to install CGAL library and
header files (the -dev package in the Debian world):
  sudo apt-install search libcgal-dev
Maybe your service provider doesn't need GDAL library, in such case, please, remove
the include lines mentioning the CGAL directory.
Hope it help,
Best,
Le 11 févr. 2011 à 17:18, truongxuan quang a écrit :
> Thank you for help,  I am  sorry!!! but I need you help again because it still getting errors  after run the 3rd command
> root at truong-desktop:/home/user/zoows/sources/zoo-services/ws_sp# gcc $CFLAGS -shared -fpic -o cgi-env/ServiceProvidder.zo ./service.c $LDFLAGS
> gcc: ../../zoo-kernel/service_internal.o: No such file or directory
> ./service.c:1:64: error: CGAL/Exact_predicates_inexact_constructions_kernel.h: No such file or directory
> ./service.c:2:54: error: CGAL/Triangulation_euclidean_traits_xy_3.h: No such file or directory
> ./service.c:3:43: error: CGAL/Delaunay_triangulation_2.h: No such file or directory
> ./service.c:4:55: error: CGAL/Constrained_Delaunay_triangulation_2.h: No such file or directory
> ./service.c:5:44: error: CGAL/Triangulation_conformer_2.h: No such file or directory
> ./service.c:6:44: error: CGAL/Triangulation_face_base_2.h: No such file or directory
> ./service.c:8:19: error: fstream: No such file or directory
> In file included from /usr/include/gdal/ogr_geometry.h:35,
>                  from /usr/include/gdal/ogr_feature.h:33,
>                  from /usr/include/gdal/ogrsf_frmts.h:33,
>                  from ./service.c:12:
> /usr/include/gdal/ogr_spatialref.h:59: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_spatialref.h:59: error: expected ‘,’ or ‘;’ before ‘OGR_SRSNode’
> /usr/include/gdal/ogr_spatialref.h:127: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_spatialref.h:127: error: expected ‘,’ or ‘;’ before ‘OGRSpatialReference’
> /usr/include/gdal/ogr_spatialref.h:515: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_spatialref.h:515: error: expected ‘,’ or ‘;’ before ‘OGRCoordinateTransformation’
> /usr/include/gdal/ogr_spatialref.h:571: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_spatialref.h:571: error: expected ‘,’ or ‘;’ before ‘*’ token
> In file included from /usr/include/gdal/ogr_feature.h:33,
> /usr/include/gdal/ogr_geometry.h:46: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRRawPoint’
> /usr/include/gdal/ogr_geometry.h:80: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:80: error: expected ‘,’ or ‘;’ before ‘OGRGeometry’
> /usr/include/gdal/ogr_geometry.h:169: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:169: error: expected ‘,’ or ‘;’ before ‘OGRPoint’
> /usr/include/gdal/ogr_geometry.h:224: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:224: error: expected ‘,’ or ‘;’ before ‘OGRCurve’
> /usr/include/gdal/ogr_geometry.h:246: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:246: error: expected ‘,’ or ‘;’ before ‘OGRLineString’
> /usr/include/gdal/ogr_geometry.h:338: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:338: error: expected ‘,’ or ‘;’ before ‘OGRLinearRing’
> /usr/include/gdal/ogr_geometry.h:381: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:381: error: expected ‘,’ or ‘;’ before ‘OGRSurface’
> /usr/include/gdal/ogr_geometry.h:402: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:402: error: expected ‘,’ or ‘;’ before ‘OGRPolygon’
> /usr/include/gdal/ogr_geometry.h:468: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:468: error: expected ‘,’ or ‘;’ before ‘OGRGeometryCollection’
> /usr/include/gdal/ogr_geometry.h:528: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:528: error: expected ‘,’ or ‘;’ before ‘OGRMultiPolygon’
> /usr/include/gdal/ogr_geometry.h:553: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:553: error: expected ‘,’ or ‘;’ before ‘OGRMultiPoint’
> /usr/include/gdal/ogr_geometry.h:579: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:579: error: expected ‘,’ or ‘;’ before ‘OGRMultiLineString’
> /usr/include/gdal/ogr_geometry.h:604: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_geometry.h:604: error: expected ‘,’ or ‘;’ before ‘OGRGeometryFactory’
> In file included from /usr/include/gdal/ogr_feature.h:34,
> /usr/include/gdal/ogr_featurestyle.h:37: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRFeature’
> /usr/include/gdal/ogr_featurestyle.h:81: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_featurestyle.h:81: error: expected ‘,’ or ‘;’ before ‘OGRStyleTable’
> /usr/include/gdal/ogr_featurestyle.h:110: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRStyleTool’
> /usr/include/gdal/ogr_featurestyle.h:115: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_featurestyle.h:115: error: expected ‘,’ or ‘;’ before ‘OGRStyleMgr’
> /usr/include/gdal/ogr_featurestyle.h:159: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_featurestyle.h:159: error: expected ‘,’ or ‘;’ before ‘OGRStyleTool’
> /usr/include/gdal/ogr_featurestyle.h:242: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_featurestyle.h:242: error: expected ‘,’ or ‘;’ before ‘OGRStylePen’
> /usr/include/gdal/ogr_featurestyle.h:290: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_featurestyle.h:290: error: expected ‘,’ or ‘;’ before ‘OGRStyleBrush’
> /usr/include/gdal/ogr_featurestyle.h:337: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_featurestyle.h:337: error: expected ‘,’ or ‘;’ before ‘OGRStyleSymbol’
> /usr/include/gdal/ogr_featurestyle.h:395: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_featurestyle.h:395: error: expected ‘,’ or ‘;’ before ‘OGRStyleLabel’
> In file included from /usr/include/gdal/ogrsf_frmts.h:33,
> /usr/include/gdal/ogr_feature.h:51: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_feature.h:51: error: expected ‘,’ or ‘;’ before ‘OGRFieldDefn’
> /usr/include/gdal/ogr_feature.h:113: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_feature.h:113: error: expected ‘,’ or ‘;’ before ‘OGRFeatureDefn’
> /usr/include/gdal/ogr_feature.h:159: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_feature.h:159: error: expected ‘,’ or ‘;’ before ‘OGRFeature’
> /usr/include/gdal/ogr_feature.h:296: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRLayer’
> /usr/include/gdal/ogr_feature.h:298: warning: data definition has no type or storage class
> /usr/include/gdal/ogr_feature.h:298: error: expected ‘,’ or ‘;’ before ‘OGRFeatureQuery’
> In file included from ./service.c:12:
> /usr/include/gdal/ogrsf_frmts.h:42: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRLayerAttrIndex’
> /usr/include/gdal/ogrsf_frmts.h:43: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘OGRSFDriver’
> /usr/include/gdal/ogrsf_frmts.h:54: warning: data definition has no type or storage class
> /usr/include/gdal/ogrsf_frmts.h:54: error: expected ‘,’ or ‘;’ before ‘OGRLayer’
> /usr/include/gdal/ogrsf_frmts.h:152: warning: data definition has no type or storage class
> /usr/include/gdal/ogrsf_frmts.h:152: error: expected ‘,’ or ‘;’ before ‘OGRDataSource’
> /usr/include/gdal/ogrsf_frmts.h:231: warning: data definition has no type or storage class
> /usr/include/gdal/ogrsf_frmts.h:231: error: expected ‘,’ or ‘;’ before ‘OGRSFDriver’
> /usr/include/gdal/ogrsf_frmts.h:264: warning: data definition has no type or storage class
> /usr/include/gdal/ogrsf_frmts.h:264: error: expected ‘,’ or ‘;’ before ‘OGRSFDriverRegistrar’
> ./service.c:15: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:18: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:19: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:21: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:22: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:25: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:26: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:27: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:29: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:31: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘:’ token
> ./service.c:33: error: expected identifier or ‘(’ before string constant
> Thanks
> T.X.Quang
> Never miss an email again!
> Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out.
Gérald Fenoy
ZOO-PSC Chair
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110211/32faf397/attachment.html>
More information about the Zoo-discuss
