[ZOO-Discuss] ZOO testing
James.Sewell at lisasoft.com James.Sewell at lisasoft.com
Wed Mar 23 22:41:39 PDT 2011
Thanks for the quick reply, I'll have another look tomorrow.
One other question, does ZOO support other OGC services for output? As an example PyWPS supports output from a process to a Mapserver WFS layer.
Is this what is happening in the ZOO Mapserver demo, or would you have to code the Mapserver component into your process in a case like this with ZOO?
Cheers,
James Sewell
Developer
LISAsoft
Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
Level 9, 601 Bourke St, Melbourne Vic 3000
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au<http://www.ardec.com.au/>
http://www.lisasoft.com<http://www.lisasoft.com/>
http://www.terrapages.com<http://www.terrapages.com/>
From: Gérald Fenoy [mailto:gerald.fenoy at geolabs.fr]
Sent: Wednesday, 23 March 2011 12:44 PM
To: James.Sewell at lisasoft.com
Cc: zoo-discuss at gisws.media.osaka-cu.ac.jp
Subject: Re: [ZOO-Discuss] ZOO testing
James,
as I said before and after checking twice, I confirm that XML POST requests are supported
even if some corrections should be done for correctly parse Body content...
Nevertheless, ZOO-Kernel never suppose that your POST request is using the following
header : "Content-Type: text/xml" or anything else. If you request the WFS server pointed in
the thread without setting header it also failed. To make the WFS POST request working using
ZOO-Kernel you should add the following node in your Reference one :
    <wps:Header key="Content-Type" value="text/xml" />
This way the header will be set correctly and the Geometry would be fetched and then
processed properly.
You can use the demo.sh file to query BufferPy service from the ZOO-Project official server.
Maybe we are wrong dealing with POST request this way, in this case please let me know.
Hope to hear from you,
Best,
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110324/9290cf7f/attachment.html>
More information about the Zoo-discuss mailing list
