[Zoo-discuss] [ZOO-Discuss] Problem with execute commands on local zooWPS setup
Farkas H farkas.dus at gmail.com
Wed Aug 8 10:32:23 PDT 2012
Hi Gérald,
thank you for your quick response.
The libraries gdal15.dll, libcur.dll, libfcgi.dll and python25.dll are
present in the kernel directory \OSGeo4W\bin.
You can find the result for the command  .\zoo_loader.cgi
"request=GetCapabilities&service=WPS" here [6].
However the URI "
http://localhost/cgi-bin/zoo_loader.cgi?ServiceProvider=&metapath=&REQUEST=GetCapabilities&SERVICE=WPS"
is working.
You can find the correct(?) browser result here [7].
Hope to here from you again.
Cheers,
Farkas
[6]
Content-Type: text/xml; charset=utf-8
Status: 200 OK
<?xml version="1.0" encoding="utf-8"?>
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
xmlns:xlink="htt
p://www.w3.org/1999/xlink" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance"
 xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/o
ws/1.1.0/owsExceptionReport.xsd" xml:lan="en" service="WPS" version="1.0.0">
  <ows:Exception exceptionCode="MissingParameterValue">
    <ows:ExceptionText>Parameter <request> was not
specified</ows:Exceptio
nText>
  </ows:Exception>
</ows:ExceptionReport>
[7]
<wps:Capabilities xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:wps="
http://www.opengis.net/wps/1.0.0" xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
http://schemas.opengis.net/wps/1.0.0/wpsGetCapabilities_response.xsd"
service="WPS" version="1.0.0" xml:lang="fr-FR">
  <ows:ServiceIdentification>
    <ows:Title>The Zoo WPS Development Server</ows:Title>
    <ows:Abstract>Development version of ZooWPS. See
http://www.zoo-project.org</ows:Abstract>
    <ows:Fees>None</ows:Fees>
    <ows:AccessConstraints>none</ows:AccessConstraints>
    <ows:Keywords>
      <ows:Keyword>WPS</ows:Keyword>
      <ows:Keyword>GIS</ows:Keyword>
      <ows:Keyword>caching</ows:Keyword>
    </ows:Keywords>
    <ows:ServiceType>WPS</ows:ServiceType>
    <ows:ServiceTypeVersion>1.0.0</ows:ServiceTypeVersion>
  </ows:ServiceIdentification>
  <ows:ServiceProvider>
    <ows:ProviderName>ZOO Project</ows:ProviderName>
    <ows:ProviderSite xlink:href="http://www.zoo-project.org"/>
    <ows:ServiceContact>
      <ows:IndividualName>Bernd</ows:IndividualName>
      <ows:PositionName>Developer</ows:PositionName>
      <ows:ContactInfo>
        <ows:Phone>
          <ows:Voice>False</ows:Voice>
          <ows:Facsimile>False</ows:Facsimile>
        </ows:Phone>
        <ows:Address>
          <ows:City>False</ows:City>
          <ows:AdministrativeArea>False</ows:AdministrativeArea>
          <ows:PostalCode>False</ows:PostalCode>
          <ows:Country>de</ows:Country>
          <ows:ElectronicMailAddress>bernd-dus at web.de
</ows:ElectronicMailAddress>
        </ows:Address>
      </ows:ContactInfo>
    </ows:ServiceContact>
  </ows:ServiceProvider>
  <ows:OperationsMetadata>
    <ows:Operation name="GetCapabilities">
      <ows:DCP>
        <ows:HTTP>
          <ows:Get xlink:href="http://localhost//"/>
        </ows:HTTP>
      </ows:DCP>
    </ows:Operation>
    <ows:Operation name="DescribeProcess">
      <ows:DCP>
        <ows:HTTP>
          <ows:Post xlink:href="http://localhost//"/>
        </ows:HTTP>
      </ows:DCP>
    </ows:Operation>
    <ows:Operation name="Execute">
      <ows:DCP>
        <ows:HTTP>
        </ows:HTTP>
      </ows:DCP>
    </ows:Operation>
  </ows:OperationsMetadata>
  <wps:ProcessOfferings>
    <wps:Process wps:processVersion="1">
      <ows:Identifier>Boundary</ows:Identifier>
      <ows:Title>Compute boundary.</ows:Title>
      <ows:Abstract>A new geometry object is created and returned
containing the boundary of the geometry on which the method is invoked.
</ows:Abstract>
      <ows:Metadata xlink:Test="Demo"/>
    </wps:Process>
    <wps:Process wps:processVersion="2">
      <ows:Identifier>Buffer</ows:Identifier>
      <ows:Title>Create a buffer around a polygon. </ows:Title>
      <ows:Abstract>Create a buffer around a single polygon. Accepts the
polygon as GML and provides GML output for the buffered feature.
</ows:Abstract>
    </wps:Process>
      <ows:Identifier>Centroid</ows:Identifier>
      <ows:Title>Get the centroid of a polygon. </ows:Title>
</ows:Abstract>
    </wps:Process>
      <ows:Identifier>ConvexHull</ows:Identifier>
      <ows:Title>Compute convex hull.</ows:Title>
containing the convex hull of the geometry on which the method is
invoked.</ows:Abstract>
    </wps:Process>
      <ows:Identifier>Difference</ows:Identifier>
      <ows:Title>Compute difference. . </ows:Title>
      <ows:Abstract>Generates a new geometry which is the region of this
geometry with the region of the other geometry removed.</ows:Abstract>
    </wps:Process>
      <ows:Identifier>Intersection</ows:Identifier>
      <ows:Title>Compute intersection. </ows:Title>
intersection of the two geometries operated on.</ows:Abstract>
    </wps:Process>
      <ows:Identifier>Ogr2Ogr</ows:Identifier>
      <ows:Title>Convert raster data from one format to another.
</ows:Title>
      <ows:Abstract>Converts raster data between different
formats.</ows:Abstract>
      <ows:Metadata xlink:title="My Demo"/>
    </wps:Process>
      <ows:Identifier>SymDifference</ows:Identifier>
      <ows:Title>Compute symmetric difference. </ows:Title>
      <ows:Abstract>Generates a new geometry which is the symmetric
difference of this geometry and the other geometry.</ows:Abstract>
    </wps:Process>
      <ows:Identifier>Union</ows:Identifier>
      <ows:Title>Compute union. </ows:Title>
      <ows:Abstract>Generates a new geometry which is the region of union
    </wps:Process>
  </wps:ProcessOfferings>
  <wps:Languages>
    <wps:Default>
      <ows:Language>fr-FR</ows:Language>
    </wps:Default>
    <wps:Supported>
      <ows:Language>en-CA</ows:Language>
    </wps:Supported>
  </wps:Languages>
</wps:Capabilities>
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20120808/6ef7b6da/attachment-0001.html>
More information about the Zoo-discuss mailing list
