[Zoo-discuss] Problems building zoo kernel
Farkas H farkas.dus at gmail.com
Sun Oct 7 21:47:37 PDT 2012
Hi Gérald,
you were right, I have built the libiconv library with the /MF flag.
I changed the flag to /MD and rebuilt all libraries with the /MD flag.
I couldn't build the iconv library (gettext-0.14.6) and got these errors [1].
commands:
   cd gettext-0.14.6
   nmake -f Makefile.msvc MFLAGS=-MD
This could be the (main) problem, because the errors are concerning
the intl.lib.
Do you have any ideas?
The dumpbin command for static libraries doesn't show any lines
containing MSVCR100.dll.
For example:
dumpbin /dependents K:\zooWPS\prg\src\zlib-1.2.7\zlib.lib
File Type: LIBRARY
  Summary
          3C .data
       1CAFC .debug$S
         3FC .debug$T
         2C1 .drectve
        429A .rdata
        9BD4 .text
The dumpbin command for dynamic libraries shows lines containing MSVCR100.dll.
For example:
dumpbin /dependents K:\zooWPS\prg\src\zlib-1.2.7\zlib1.dll
File Type: DLL
  Image has the following dependencies:
    MSVCR100.dll
    KERNEL32.dll
  Summary
        1000 .data
        5000 .rdata
        1000 .reloc
        1000 .rsrc
        B000 .text
I couldn't run a clean before building the kernel.
I got the following error.
NMAKE : fatal error U1052: file 'clean' not found
Hope to hear from you.
Regards,
Farkas
[1]
   Creating library msgcmp.lib and object msgcmp.exp
gettextlib.lib(xerror.obj) : warning LNK4049: locally defined symbol _program_na
me imported
msgcmp.obj : warning LNK4217: locally defined symbol _program_name imported in f
unction _usage
gettextsrc.lib(msgl-iconv.obj) : warning LNK4049: locally defined symbol _progra
m_name imported
gettextsrc.lib(po-charset.obj) : warning LNK4049: locally defined symbol _progra
m_name imported
gettextlib.lib(error-progname.obj) : warning LNK4049: locally defined symbol _pr
ogram_name imported
msgcmp.obj : warning LNK4217: locally defined symbol _optind imported in functio
n _main
msgcmp.obj : warning LNK4217: locally defined symbol _optarg imported in functio
n _main
msgcmp.obj : warning LNK4217: locally defined symbol _input_syntax imported in f
unction _main
msgcmp.obj : warning LNK4217: locally defined symbol _gram_max_allowed_errors im
ported in function _main
msgcmp.obj : warning LNK4217: locally defined symbol _error_print_progname impor
gettextsrc.lib(po-lex.obj) : warning LNK4217: locally defined symbol _error_mess
age_count imported in function _po_gram_error
gettextsrc.lib(read-po-abstract.obj) : warning LNK4049: locally defined symbol _
error_message_count imported
gettextlib.lib(xerror.obj) : warning LNK4049: locally defined symbol _error_mess
age_count imported
gettextsrc.lib(po-lex.obj) : warning LNK4217: locally defined symbol _error_with
_progname imported in function _po_gram_error
gettextsrc.lib(read-properties.obj) : warning LNK4049: locally defined symbol _e
rror_with_progname imported
gettextsrc.lib(read-stringtable.obj) : warning LNK4217: locally defined symbol _
error_with_progname imported in function _phase1_getc
gettextlib.lib(xerror.obj) : warning LNK4049: locally defined symbol _error_with
_progname imported
gettextsrc.lib(po-lex.obj) : warning LNK4217: locally defined symbol _po_lex_cha
rset imported in function _mb_width
gettextsrc.lib(po-lex.obj) : warning LNK4217: locally defined symbol _po_lex_ico
nv imported in function _mb_width
gettextsrc.lib(po-lex.obj) : warning LNK4217: locally defined symbol _po_lex_wei
rd_cjk imported in function _mbfile_getc
gettextsrc.lib(po-lex.obj) : warning LNK4217: locally defined symbol _po_gram_lv
al imported in function _po_gram_lex
gettextsrc.lib(msgl-iconv.obj) : warning LNK4217: locally defined symbol _po_cha
rset_ascii imported in function _iconv_message_list
gettextsrc.lib(read-po.obj) : warning LNK4217: locally defined symbol _gram_pos
imported in function _default_set_domain
gettextsrc.lib(po-gram-gen.obj) : warning LNK4049: locally defined symbol _gram_
pos imported
gettextsrc.lib(read-po.obj) : warning LNK4217: locally defined symbol _po_charse
t_utf8 imported in function _read_po
gettextsrc.lib(read-po-abstract.obj) : warning LNK4217: locally defined symbol _
format_language imported in function _po_parse_comment_special
gettextsrc.lib(po-gram-gen.obj) : warning LNK4217: locally defined symbol _pass_
obsolete_entries imported in function _po_gram_parse
gettextsrc.lib(po-lex.obj) : error LNK2019: unresolved external symbol __imp__po
_error referenced in function _po_gram_error
gettextsrc.lib(read-po-abstract.obj) : error LNK2001: unresolved external symbol
 __imp__po_error
_error_at_line referenced in function _po_gram_error_at_line
gettextsrc.lib(po-charset.obj) : error LNK2019: unresolved external symbol __imp
__po_multiline_warning referenced in function _po_lex_charset_set
gettextlib.lib(obstack.obj) : error LNK2019: unresolved external symbol __imp__e
xit_failure referenced in function _print_and_abort
msgcmp.exe : fatal error LNK1120: 4 unresolved externals
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio 10.0
\VC\BIN\cl.EXE"' : return code '0x2'
Stop.
\VC\BIN\nmake.exe"' : return code '0x2'
Stop.
On 5 October 2012 13:46, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
> Hello Farkas,
> I don't think that the issue with linkage is due to the ZOO-Kernel itself but on the way you built the dependencies. Indeed, it seems that you mixed /MT and /MD on the way. Which means that I suppose you built some dependent library using /MT flag when you should use /MD.
> To verify that my supposition is correct, please use the following command on each of your dependent libraries (after running the vcvars32.bat script from Visual Studio 10.0):
> dumpbin /dependents <MY_LIBRARY>
> By replacing <MY_LIBRARY> by the full path of your dependent library. Make sure that you always get the following lines:
> MSVCR100.dll
> For each library which doesn't contain this line, please rebuild after making sure you use well /MD flags for code generation rather than /MT.
> Note that, in the log provided it seems that you tried first to build the ZOO-Kernel with JAVA activated then you go back on the same tree to compile again deactivating this support. This is one of the trouble you faced corresponding to your first LNK2019 message. Tosolve this issue, you may try to run nmake /d Makefile.vc clean before trying to build the ZOO-Kernel.
> For the libiconv library, I remember getting similar issue before. I think that it may be of some help so I've uploaded an archive [1] containing the source tree I used to build the library. Note that the archive also contains the 32 Bits version of the dll pre-build.
> I hope this help you to go further and that you can build the ZOO-Kernel on Windows.
> Hope to hear back from you,
> Best regards,
> [1] http://zoo-project.org/dl/libiconv-win32-1.14.7z
> Gérald Fenoy
> Le 4 oct. 2012 à 18:05, Farkas H <farkas.dus at gmail.com> a écrit :
>> Hi Gérald,
>> thank you for your quick response.
>> I tried to build the zoo-kernel without JS and MapServer support and
>> got these linker errors [1].
>> What am I doing wrong?
>> I would appreciate any advice.
>> Further I got these compiler errors building the intl library. I
>> couldn't find a workaround for version 0.14.6. I commented the
>> relevant lines and built the intl library.
>> Do you know a solution?
>> Regards,
>> Farkas
>> [1]
>> LIBCMT.lib(dosmap.obj) : error LNK2005: __errno already defined in
>> MSVCRT.lib(MSVCR100.dll)
>> LIBCMT.lib(crt0dat.obj) : error LNK2005: _exit already defined in
>> LIBCMT.lib(setmode.obj) : error LNK2005: __setmode already defined in
>> LIBCMT.lib(winsig.obj) : error LNK2005: _signal already defined in
>> LIBCMT.lib(winsig.obj) : error LNK2005: _raise already defined in
>> MSVCRT.lib(MSVCR100.dll) : error LNK2005: __write already defined in
>> LIBCMT.lib(write.obj)
>> MSVCRT.lib(MSVCR100.dll) : error LNK2005: __open already defined in
>> LIBCMT.lib(open.obj)
>> MSVCRT.lib(MSVCR100.dll) : error LNK2005: __close already defined in
>> LIBCMT.lib(close.obj)
>>   Creating library zoo_loader.lib and object zoo_loader.exp
>> LINK : warning LNK4098: defaultlib 'MSVCRT' conflicts with use of
>> other libs; use /NODEFAULTLIB:library
>> zoo_service_loader.obj : error LNK2019: unresolved external symbol
>> _zoo_java_support referenced in function "void __cdecl
>> loadServiceAndRun(struct maps * *,struct service *,struct map *,struct
>> maps * *,struct maps * *,int *)"
>> (?loadServiceAndRun@@YAXPAPAUmaps@@PAUservice@@PAUmap@@00PAH at Z)
>> intl.lib(loadmsgcat.obj) : error LNK2019: unresolved external symbol
>> __imp__libiconv_open referenced in function __nl_init_domain_conv
>> __imp__libiconv_close referenced in function __nl_free_domain_conv
>> intl.lib(dcigettext.obj) : error LNK2019: unresolved external symbol
>> __imp__libiconv referenced in function __nl_find_msg
>> intl.lib(relocatable.obj) : error LNK2019: unresolved external symbol
>> __imp__libiconv_set_relocation_prefix referenced in function
>> _libintl_set_relocation_prefix
>> zoo_loader.cgi : fatal error LNK1120: 5 unresolved externals
>> [2]
>> localename.c
>> .\localename.c(1360) : error C2196: case value '1' already used
>> .\localename.c(1368) : error C2196: case value '1' already used
>> On 4 October 2012 11:58, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
>>> Dear Farkas,
>>> to be able to build curl I modified the line 175 of the MakefileBuild.vc to add the following to the CFLAGS:
>>> /DWANT_IDN_PROTOTYPES
>>> This was quoted here [1].
>>> Then, I used the following command to build the library:
>>> cd winbuild
>>> copy ..\..\zlib-1.2.7\*.h ..\..\deps\include
>>> nmake /f Makefile.vc mode=dll WITH_ZLIB=dll VC=10 ENALE_IDN=yes
>>> Note that the method described to build zlib should work correctly using cmake, here I used cmake version 2.8.7 windows binary.
>>> Hope this helps,
>>> [1] http://www.mail-archive.com/curl-library@cool.haxx.se/msg13683.html
>>> Gérald Fenoy
>>> Le 4 oct. 2012 à 00:18, Farkas H <farkas.dus at gmail.com> a écrit :
>>>> Hi Gérald,
>>>> thanks to your support I'm slowly getting the ropes together.
>>>> I've updated on Microsoft Visual Express 2010 and SDK 7.1.
>>>> Building zlib library worked fine. I had to change the nmake command though.
>>>> nmake -f win32/Makefile.msc OBJA=inffast.obj
>>>> I had no problems building libiconv library and libxml2 library.
>>>> But I couldn't build libcurl library. I got the following errors:
>>>> idn_win32.obj : error LNK2019: unresolved external symbol _IdnToAscii
>>>> referenced in function _curl_win32_idn_to_ascii
>>>> _IdnToUnicode referenced in function _curl_win32_ascii_to_idn
>>>> Do you have any idea?
>>>> I would appreciate any advice and if you could also provide your build
>>>> commands for the other libraries.
>>>> Regards,
>>>> Farkas
>>>> On 3 October 2012 11:18, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
>>>>> Hi Farkas,
>>>>> sorry for late reply.
>>>>> Thanks for notifying the double target which explain why I got the error message when trying to compile again the same tree… This is now fixed in trunk.
>>>>> Personally I am using the Microsoft Visual Express Edition 2010 and SDKs 7.0A or 7.1. I saw that you used 6.0A but this should not cause issue I guess.
>>>>> To compile the curl library I used the following command:
>>>>> cd winbuild
>>>>> In your case I guess that you should use VC=9 .
>>>>> Note that I built zlib first using the following command:
>>>>> cd zlib-1.2.7
>>>>> cmake . -DCMAKE_BUILD_TYPE=Release
>>>>> nmake
>>>>> To build the libxml2 I used the following command:
>>>>> cd \MMBK\SRCS\libxml2-2.8.0\win32\
>>>>> cscript configure.js compiler=msvc zlib=yes python=yes
>>>>> mkdir include
>>>>> mkdir bin.msvc
>>>>> copy \MMBK\SRCS\zlib-1.2.7\zconf.h include
>>>>> copy \MMBK\SRCS\zlib-1.2.7\zlib.h include
>>>>> copy D:\MMBK\SRCS\libiconv-win32-1.14\libiconv-win32-1.14\iconv.h include
>>>>> copy \MMBK\SRCS\libiconv-win32-1.14\obj\libiconv-win32-1.14\Release_Win32\libiconv-win32-1.14.lib bin.mscv
>>>>> nmake
>>>>> Note that one more time I built the libiconv first. For this you can follow instructions from [1]
>>>>> I hope that this will answer your question and will help you to go further.
>>>>> Best regards,
>>>>> [1] http://www.codeproject.com/Articles/302012/How-to-Build-libiconv-with-Microsoft-Visual-Studio
>>>>> Gérald Fenoy
>>>>> Le 1 oct. 2012 à 18:15, Farkas H <farkas.dus at gmail.com> a écrit :
>>>>>> Hi Gérald,
>>>>>> thank you very much for updating the source code.
>>>>>> Compiling the source code of the zoo-kernel works fine.
>>>>>> I got a few warning messages. The makefile.vc contains two rules for
>>>>>> the target service_internal_java.obj.
>>>>>> Unfortunately I cannot link the .obj files because I didn't manage to
>>>>>> build the required libraries.
>>>>>> I was trying different ways, but I didn't manage it. Maybe it's a
>>>>>> general problem with my setup?!
>>>>>> I give you two examples [3], [4].
>>>>>> Does it make sense instead of building the required libraries, copying
>>>>>> the necessary .lib files to the file-structure?
>>>>>> I really appreciate any advice.
>>>>>> Hope to here back from you.
>>>>>> Thanks,
>>>>>> Farkas
>>>>>> [2]
>>>>>> Curl: nmake /f Makefile.vc mode=dll
>>>>>> ..\builds\libcurl-release-dll-ipv6-sspi-winssl-obj-lib\libcurl.dll :
>>>>>> fatal error LNK1120: 2 unresolved externals
>>>>>> [3]
>>>>>> libxml2: nmake /f Makefile.msvc
>>>>>> ..\include\libxml/nanoftp.h(34) : warning C4005: 'INVALID_SOCKET' :
>>>>>> macro redefinition
>>>>>>      C:\Program Files\Microsoft
>>>>>> SDKs\Windows\v6.0A\include\winsock2.h(387) : see previous definition
>>>>>> of 'INVALID_SOCKET'
>>>>>> nanohttp.c
>>>>>> ..\nanohttp.c(574) : error C2065: 'EINPROGRESS' : undeclared identifier
>>>>>> ..\nanohttp.c(574) : error C2051: case expression not constant
>>>>>> ..\nanohttp.c(581) : error C2065: 'ECONNRESET' : undeclared identifier
>>>>>> ..\nanohttp.c(581) : error C2051: case expression not constant
>>>>>> ..\nanohttp.c(922) : error C2065: 'EINPROGRESS' : undeclared identifier
>>>>>> ..\nanohttp.c(922) : error C2051: case expression not constant
>>>>>> On 29 September 2012 16:19, Gérald Fenoy <gerald.fenoy at geolabs.fr> wrote:
>>>>>>> Dear Farkas,
>>>>>>> many thanks for your perseverance :)
>>>>>>> First of all I would like to thanks specifically: Espen Messel, Knut Landmark and Bernd Härtwig for providing patches during their own testings in building ZOO-Kernel on Windows Platforms. I can applied their patches easily and they made my work easier by providing first feedbacks.
>>>>>>> I would also like to thanks you Frakas for continuously ask for Windows support in ZOO-Project privately and even better using the ZOO-Discuss mailing list.
>>>>>>> Anyway, I'm please to tell you that after long time I finally updated the SVN source tree on the official ZOO-Project SVN server to follow the developments I made some times ago. Nevertheless, as discussed with Angelos I was not able, before this morning, to run properly the Java Services but I finally succeed on that side of the ZOO-Kernel also and it successfully build (which was not the worth case finally) but *run* also successfully using the JDK-1.7.0_07.
>>>>>>> About the specific requirements for running Java Services on windows platform, if you run ZOO-Kernel in 32 bits mode then ZOO-Kernel will have to fix the maximum size of the JVM to 512M (note that, following JNI instructions, we should be able togo until 1G and a bit more) using the -Xmx512M option to run initialize the JVM. Note that this will probably cause trouble to those which are requiring more than 512 M of memory to run their services, so mate we should think about a [jvm] section in main.cfg to setup all this. You will also need to define your PATH environment variable to add to it your local jdk setup, you never have to mode the jvm.dll to the  ZOO-Kernel directory else when initializing the JVM you will get error message mentioning: "Can't find dependent libraries ".
>>>>>>> Note that now, you can also activate the ZOO-Kernel MapServer internal support which let you automatically publish results out of your services as WMS/WFS/WCS. As many knows on windows platforms you will need some specific parameters defined into the MapFile at the map level to define CONFIG options such as PROJ_LIB and GDAL-DATA. So to solve this issue, we added a dedicated [mapserver] section in the main.cfg which let you define all the specific options you need to set to make your MapServer setup working.
>>>>>>> The tests I've run on Windows platforms was based on a ZOO-Kernel including the following support : Python, JavaScript, Java and MapServer and the tests runs successfully.
>>>>>>> As you can see in the nmake.opt and following method used in GDAL and MapServer nmake.opt, we setup parameters to pass to your nmake command to add supports to your ZOO-Kernel. So, this way, Python, JavaScript, Java and MapServer are now optional and can be defined at compile time.
>>>>>>> For instance, I personally used the following command line to compile the ZOO-Kernel on my windows platform:
>>>>>>> nmake /f makefile.vc FCGI_DIR=\MMBK\SRCS\fcgi-2.4.1-SNAP-0311112127 INTL_DIR=\MMBK\SRCS\gettext-0.14.6\gettext-runtime\intl SSL_DIR=\MMBK\SRCS\openssl-1.0.1c CURL_DIR=D:\MMBK\SRCS\curl-7.27.0\builds\libcurl-release-dll-zlib-dll-ipv6-sspi-winssl XML2_DIR=\MMBK\SRCS\libxml2-2.8.0 ICONV_DIR=\MMBK\SRCS\libiconv-win32-1.14\libiconv-win32-1.14 PY_DIR=\MMBK\SRCS\Python-2.7.3 PY_LIBRARY=\MMBK\SRCS\Python-2.7.3\PCbuild\python27.lib MS_DIR=\MMBK\SRCS\mapserver-6.0.3 GDAL_DIR=\MMBK\SRCS\gdal-1.9.1 GD_DIR=\MMBK\SRCS\pierrejoye-gd-libgd-733361a31aab\src JS_DIR=\MMBK\SRCS\js-1.8.5\js\src JDK_DIR="c:\Program Files (x86)\Java\jdk1.7.0_07"
>>>>>>> So to conclude, I think that you should start compiling the ZOO-Kernel again using the latest source code available in the official ZOO-Project SVN server and you should succeed.
>>>>>>> Hope to hear back from you to know how it works on your side.
>>>>>>> Best regards,
>>>>>>> Gérald Fenoy
>>>>>>> Le 28 sept. 2012 à 16:49, Farkas H <farkas.dus at gmail.com> a écrit :
>>>>>>>> Hi list,
>>>>>>>> I try to build the zoo kernel (Win7-64, MSVC9). Amongst others I got
>>>>>>>> these warnings and error messages [1].
>>>>>>>> It would be nice if someone could help me. I got stuck.
>>>>>>>> Thanks,
>>>>>>>> Farkas
>>>>>>>> [1]
>>>>>>>> K:\zooWPS\zoo-project\..\libs\fcgi\include\fcgio.h(53) : warning
>>>>>>>> C4251: 'std::basic_streambuf<_Elem,_Traits>::_Mylock' : class
>>>>>>>> 'std::_Mutex' needs to have dll-interface to be used by clients of
>>>>>>>> class 'std::basic_streambuf<_Elem,_Traits>'
>>>>>>>>     with
>>>>>>>>         _Elem=char,
>>>>>>>>         _Traits=std::char_traits<char>
>>>>>>>> 9.0\VC\INCLUDE\yvals.h(723) : see declaration of 'std::_Mutex'
>>>>>>>> K:\zooWPS\zoo-project\..\libs\fcgi\include\fcgio.h(107) : warning
>>>>>>>> C4996: 'std::basic_streambuf<_Elem,_Traits>::xsgetn': Function call
>>>>>>>> with parameters that may be unsafe - this call relies on the caller to
>>>>>>>> check that the passed values are correct. To disable this warning, use
>>>>>>>> -D_SCL_SECURE_NO_WARNINGS. See documentation on how to use Visual C++
>>>>>>>> 'Checked Iterators'
>>>>>>>>     with
>>>>>>>>         _Elem=char,
>>>>>>>> 9.0\VC\INCLUDE\streambuf(323) : see declaration of
>>>>>>>>     with
>>>>>>>>         _Elem=char,
>>>>>>>> K:\zooWPS\zoo-project\..\libs\fcgi\include\fcgio.h(113) : warning
>>>>>>>> C4275: non dll-interface class 'std::ios_base' used as base for
>>>>>>>> dll-interface class 'std::basic_ios<_Elem,_Traits>'
>>>>>>>>     with
>>>>>>>>         _Elem=char,
>>>>>>>> 9.0\VC\INCLUDE\xiosbase(195) : see declaration of 'std::ios_base'
>>>>>>>> k:\zoowps\zoo-project\zoo-kernel\service.h(51) : warning C4005:
>>>>>>>> 'SERVICE_PAUSED' : macro redefinition
>>>>>>>> SDKs\Windows\v6.0A\include\winsvc.h(116) : see previous definition of
>>>>>>>> 'SERVICE_PAUSED'
>>>>>>>> k:\zoowps\zoo-project\zoo-kernel\service.h(154) : warning C4996:
>>>>>>>> 'strdup': The POSIX name for this item is deprecated. Instead, use the
>>>>>>>> ISO C++ conformant name: _strdup. See online help for details.
>>>>>>>> 9.0\VC\INCLUDE\string.h(207) : see declaration of 'strdup'
>>>>>>>> k:\zoowps\zoo-project\zoo-kernel\service.h(173) : warning C4996:
>>>>>>>> 'stricmp': The POSIX name for this item is deprecated. Instead, use
>>>>>>>> the ISO C++ conformant name: _stricmp. See online help for details.
>>>>>>>> 9.0\VC\INCLUDE\string.h(215) : see declaration of 'stricmp'
>>>>>>>> k:\zoowps\zoo-project\zoo-kernel\service.h(623) : warning C4996:
>>>>>>>> 'strnicmp': The POSIX name for this item is deprecated. Instead, use
>>>>>>>> the ISO C++ conformant name: _strnicmp. See online help for details.
>>>>>>>> 9.0\VC\INCLUDE\string.h(217) : see declaration of 'strnicmp'
>>>>>>>> zoo_loader.c(63) : warning C4005: 'FALSE' : macro redefinition
>>>>>>>> SDKs\Windows\v6.0A\include\windef.h(68) : see previous definition of
>>>>>>>> 'FALSE'
>>>>>>>> zoo_loader.c(70) : warning C4996: 'dup2': The POSIX name for this item
>>>>>>>> is deprecated. Instead, use the ISO C++ conformant name: _dup2. See
>>>>>>>> 9.0\VC\INCLUDE\io.h(309) : see declaration of 'dup2'
>>>>>>>> zoo_loader.c(298) : error C3861: 'strtok_r': identifier not found
>>>>>>>> zoo_loader.c(303) : error C3861: 'strtok_r': identifier not found
>>>>>>>> zoo_loader.c(309) : error C3861: 'strtok_r': identifier not found
>>>>>>>> zoo_loader.c(316) : error C3861: 'strtok_r': identifier not found
>>>>>>>> _______________________________________________
>>>>>>>> Zoo-discuss mailing list
>>>>>>>> Zoo-discuss at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
