[Zoo-discuss] Ubuntu with ZOO Virtual Image
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Sep 21 07:34:46 PDT 2012
On 09/21/2012 04:07 PM, Venkatesh Raghavan wrote:
> Hi Deniel,
> On 2012/09/21 21:12, Daniel Kastl wrote:
>> You could just use OSGeo Live DVD:
> I did just the same. In fact I used the OSGeo-Live VM at
> http://download.osgeo.org/livedvd/release/6.0/osgeo-live-mini-6.0.iso/download
> The ZOO demos in OSGeo-Live worked with out any problem.
> I had to install fastcgi, bison, flex and cgic devel packages required
> for compiling
> the zoo-kernel.
> Also, OSGeo-Live uses gdal-1.7.0 did a minor change on ZOO-kernel
> configure and make  to reflect the
> updated gdal-1.9.0.
> Downloaded  zoo-1.2.0 from
> http://zoo-project.org/site/Downloads#ZOO-Projectversion1.2.0
> and it compiled without any problem. Could compile the gdal raster
> services subsequently
> (will test them soon).
> I hope to install GRASS7 and work on more examples on ZOO raster
> processing and routing
> examples. Subsequently, hope to make new virtual machine with added
> features (GRASS7 for
> example) with the help of Markus, Frans and all of you.
> Best
> Venka
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Hi Venka,
Good choice to start from OSGeoLive VM, it is well tested.
I have another solution: when creating the ZOO-Kernel RPM packages for
openSUSE I had included a grass7-bridge package too (grass7 is available
in openSUSE for some time now). I could use SUSEStudio to easily create
a LiveCD with ZOO-Kernel, grass7 and the bridge package.
https://build.opensuse.org/package/show?package=zoo-kernel&project=Application%3AGeo
https://build.opensuse.org/package/binaries?package=zoo-kernel&project=Application%3AGeo&repository=openSUSE_12.2
Let me know if you need this.
Regards,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Zoo-discuss mailing list
