[Zoo-discuss] Ubuntu with ZOO Virtual Image
Gérald Fenoy
gerald.fenoy at geolabs.fr
Thu Sep 27 04:48:33 PDT 2012
Dear Angelos,
thanks a lot for your feedbacks.
As you probably noticed, libcgic is only a compile-time dependencies and the ZOO-Kernel is *statically* linked to its own libcgic so you never have to install this version of libcgic on your system. You should probably plan to remove this dependencies because as you said it may cause trouble for other softwares using libcgic.
I really think that is not an issue and that the dependency can be removed.
Hope this helps.
Best regards,
Gérald Fenoy
Le 27 sept. 2012 à 13:43, Angelos Tzotsos <gcpp.kalxas at gmail.com> a écrit :
> The dependencies issue is a bit of a trouble. I had to create an alternative package for libcgic in openSUSE, while this was maintained in the distribution under another version. This can break some systems trying to run both versions and is still unresolved :(
More information about the Zoo-discuss
