[Zoo-discuss] WPS
Anunay Sinha anunay.sinha88 at gmail.com
Thu Nov 28 22:17:51 PST 2013
Hi
I am getting the following error. *Unable to load the main.cfg file*
Since this is the first time am trying to load CGI Module I will list down
the steps I have followed.
 1. Downloaded the package and extracted it to *C:\inetpub\wwwroot\*.
 2. Edited the main.cfg present inside C:\inetpub\wwwroot\Dist\cgi-bin
folder. Replace the d:/ZOO_INSTALL_PATH and  d:\ZOO_INSTALL_PATH with
 3. Next I went to the IIS Manager. Under the Sites -> Default Web Site ->
Dist -> CGI-bin. I selected Handler Mappings from feature list and ensured
the Read Script and Execute permissions are checked.
 4. Then I added the Zoo_loader.cgi and Mapservr.cgi in ISAP and CGI
Restrictions
 5. Re stared the server
 6. And browse for the following :
http://localhost:8087/dist/cgi-bin/zoo_loader.cgi (I also modified my
main.cfg file for this address
*serverAddress=http://localhost:8087/dist/cgi-bin/zoo_loader.cgi
<http://localhost:8087/dist/cgi-bin/zoo_loader.cgi>*)
  7.  I am getting the following xml in the response.
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="
http://www.w3.org/1999/xlink" xsi:schemaLocation="
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd" xml:lang="en-US
" version="1.1.0">
<ows:Exception exceptionCode="InternalError">
<ows:ExceptionText>Unable to load the main.cfg file.</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
I am looking into it to see if this is an configuration issue at my end, or
if i have missed some thing that you can point out, it will be really
helpful.
Thank's
Anunay
On Thu, Nov 28, 2013 at 2:17 PM, Anunay Sinha <anunay.sinha88 at gmail.com>wrote:
> I was myself missing from the action from last two days. Will download and
> post you back on how it went
> Thanks for providing it to us.
> Anunay
> On Wed, Nov 27, 2013 at 3:46 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>wrote:
>> Dear Anunay,
>> sorry for being so long for providing the solution.
>> I fact I psnet some time on saturday afternoon to make the ZOO-Project
>> demonstrations user interface working on windows but I cannot figure out
>> why MapServer is not answering any request coming using POST method so I
>> cannot provide a full featured demo User Interface as I would like to
>> provide to you. But as I also think that providing something even without
>> demo user interface to interact directly with the WPS Server is more than
>> nothing.
>> I put the binary version of the ZOO-Project for Win32 on ZOO-Project.org
>> web site [1]. Note that the file is quite huge but it contains the full
>> build tree for Python-2.7.3 including all requested modules (and even more,
>> let say some modules which are not directly required by ZOO-Project).
>> Once you uncompressed the archive somewhere on windows platform, then you
>> will simply have to activate the CgI module from your IIS instance, then
>> define a virtual directory pointing to your cgi-bin directory. Once all
>> that was done, replace all occurrence of « d:/ZOO_INSTALL_PATH » and «
>> d:\ZOO_INSTALL_PATH » by the correct location where you uncompressed the
>> archive.
>> I hope that this setup will work correctly on your side and you can run
>> your tests of the ZOO-Project WPS Server implementation.
>> Hope to hear back from you,
>> Best regards,
>> Gérald Fenoy
>> [1] http://zoo-project.org/dl/zoo-windist.7z
>> Le 23 nov. 2013 à 11:52, Fenoy Gerald <gerald.fenoy at geolabs.fr> a écrit :
>> > Hello Anunay,
>> > sorry for the delay, I’m currently packaging ZOO-Project distribution
>> to be usable on IIS with few services.
>> > Note that more than only ZOO-Project will have to be packaged, indeed I
>> would like to provide a working Python support so implying that it will
>> require a full distribution of Python-2.7.3. You should not use another
>> Python distribution than the one which will be provided.
>> > There is no real issue with the Python archive and deployment.
>> Nevertheless, I would like to insist on the fact that some issue will
>> probably occur when you will try to use some python utilities located in
>> Script directory, so better to avoid using this tools. Note that you can
>> always fix the files locally to fit with your setup if you want to use
>> them. But Python interpreter will work correctly and will be usable from
>> the ZOO-Kernel.
>> > Anyway, there is currently no documentation on how to setup ZOO-Project
>> on IIS by now, but I will try my best to provide instruction when the
>> binary distribution will be ready. It should be available soon this
>> afternoon. To make things easier, I have to remove all services you do not
>> need and to use a different tree into cgi-bin to avoid to make you search
>> for the location where services are located to use the correct metapath.
>> > Be back to you soon with link to the documentation.
>> > Best regards,
>> > Le 23 nov. 2013 à 11:28, Anunay Sinha <anunay.sinha88 at gmail.com> a
>> écrit :
>> >> HI,
>> >> Can you let me know where I can find the instructions for running Zoo
>> Kernel on IIS Server.
>> >> We really wanna have ZooWPS running.
>> >> Thanks for your efforts and help.
>> >> Anunay
>> >> On Thu, Nov 21, 2013 at 2:44 PM, Anunay Sinha <
>> anunay.sinha88 at gmail.com> wrote:
>> >> I think for now I can go ahead and use the bianries on the IIS server.
>> >> But eventually we need to integrate it with the our GIS Engine. So I
>> Have to build from the tree. But I can delay this part for now.
>> >> As of now if I can just run it on IIS with some test services, that
>> will be all.
>> >> So please provide those binaries so that I can have these services
>> running
>> >> Also if you have some other document which can elaborate on building
>> WPS from the source for IIS with external libraries that will be really
>> helpful.
>> >> Thanks for your quick response.
>> >> Anunay
>> >> On Thu, Nov 21, 2013 at 2:30 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>
>> wrote:
>> >> Hello Anunay,
>> >> I think it is wrong to try to use this *really* old win32 binaries.
>> >> We are currently using a new version ZOO-Kernel including the Python
>> and Javascript languages support and also the MapServer support.
>> >> The MapServer support is, by now, based on a modified version of
>> MapServer 6.2.0 including various patches to fix encoding issue with WFS /
>> GetFeatureInfo request.
>> >> As we were asked for we focussed our work on IIS this time. We do not
>> support Apache anymore on Windows platforms. Note that if you are using a
>> Windows 7 professional then you get the IIS server available so it should
>> not hurt that much. Anyway when you will want to deploy your solution you
>> will probably use Windows Server something™ :)
>> >> So I think that the best solution for you should be to use the same
>> binary version we are currently using in production projects based on
>> Windows. To make sure you will be able to run it, except from command line
>> (indeed ZOO-Kernel can be easily run from command line on windows
>> platforms), you should first confirm that you get an IIS instance available
>> somewhere where you can run tests.
>> >> In such a case I will publish the newer version I have available
>> (latest trunk ZOO-Kernel, MapServer 6.2.0, GDAL 1.10.1, Python 2.7.3) all
>> those softwares were built using Microsoft Visual Studio 2010 Express
>> Edition (the « free » one). It depends on Microsoft Visual C++ 2010
>> Redistributable Package available for download here: [1].
>> >> Note that despite I can provide both main.cfg and binary distribution
>> of ZOO-Project (including C services already build) I guess there will
>> still be some things missing for you. Indeed, you said that you are willing
>> to integrate your own services. Which is standard thing, nevertheless if
>> you plan to implement your services in C then it means that getting only
>> the binaries won’t help you that much. Indeed, you will need the full build
>> tree to be able to build and link your own binaries against the depending
>> ones. Note that if you planned to implement your services by using
>> JavaScript and / or Python language then you won’t have any issue in using
>> only the binaries.
>> >> There is a last issue with which I’m not really familiar is that the
>> GDAL binary was linked against the ECW binary libraries provided by Erdas.
>> But I wonder if I am allowed to distribute this specific DLL or not. I
>> think I am not allowed.
>> >> Anyway, please confirm that the binary solution is enough for you then
>> I will upload the binaries for you on the ZOO-Project.org web site.
>> >> Hope to hear back from you soon,
>> >> Best regards,
>> >> [1] http://www.microsoft.com/en-us/download/details.aspx?id=5555
>> >> Le 21 nov. 2013 à 08:10, Anunay Sinha <anunay.sinha88 at gmail.com> a
>> écrit :
>> >>> I am trying to install ZooWPS on Windows. I am having some trouble
>> with the prerequisites. They are not very specific with the version numbers
>> of the corresponding softwares.
>> >>> 1. Anyhow I went ahead and downloaded the latest stable
>> releases(Binaries wherever I can and compiled the rest).
>> >>> 2. Next I compiled Libgic
>> >>> 3. I Downloaded the OSGGeo4W (It asked about Desktop and WEBGIS and I
>> selected Desktop)
>> >>> 4. Next It asked me to download "This Package" which was
>> tool-win32.zip (I am not sure where to add this. For now I have kept it in
>> my path)
>> >>> 5. Next it talked about full runtime dependencies to be places in
>> C:OSGeo4WBin (I am assuming it is c:\OSGeo4w\bin
>> >>> 6. Next was to download zoo_loader.cgi and the Main.cfg file (I
>> cannot find the Main.cfg file and still looking around for the content of
>> the file)
>> >>> 7. Next was to get OGR Service Providers which were provided in
>> Zoo-services-win32.zip. I have placed them in C:\OSGeo4W\bin (It talked
>> about two libraries but i simple copied everything into the bin. Was not
>> sure which two are we talking about here )
>> >>> I have no previous experience with CGI and C coded servers so am
>> missing a lot of things here. For instance I dont know where the server is
>> and how to start it? I am looking into these things, but since this whole
>> effort was sort of a POC i will really appreciate if some one can help me
>> run the zoo kernel with OGR and once with my exiting code. So that we can
>> see how it works and decide on what WPS framework to choose.
>> >>> In the mean time I am trying to bridge this gap and get more info on
>> CGI.
>> >>> Thanks for your efforts.
>> >>> Anunay
>> >>> On Tue, Nov 19, 2013 at 1:36 AM, nicolas bozon <
>> nicolas.bozon at gmail.com> wrote:
>> >>> Anunay,
>> >>> If your code base is in C++, i would definitively recommend you give
>> ZOO a try.
>> >>> You could probably use your existing C++ and take advantage of the
>> available GDAL and GRASS support we maintain.
>> >>> Also, the MapServer support (i.e the resulting data source(s) of your
>> WPS request is automatically written to a mapfile and it thus makes it very
>> easy to publish as WMS/WFS/WCS) provided by ZOO 1.3 may be of interest for
>> your needs.
>> >>> FYI, such capabilities are also used into our MapMint platform, which
>> provides an admin interface to both ZOO, GDAL, MapServer and OpenLayers and
>> that will soon be released open source too.
>> >>> Do not hesitate to ask more practical/technical questions publicly or
>> privately if needed.
>> >>> Hope it helps
>> >>> Best,
>> >>> Nick
>> >>> 2013/11/18 Anunay Sinha <anunay.sinha88 at gmail.com>
>> >>> Thanks.
>> >>> Will post it up there.
>> >>> I was for a second interested in Zoo for the same reason (My GIS
>> Engine was initially in C++ so wrapping it with C will be easy compared
>> with the overhead it requires for other languages ). I just wanted to know
>> how is Zoo compared with the rest?
>> >>> In terms of acceptance in the market. And what are the points I need
>> to take into consideration when choosing one over the other (you gave me
>> one point, if there are more?)
>> >>> I will put up this post in the mailing list you mentioned but just to
>> continue the discussion am keeping this thread running.
>> >>> On Mon, Nov 18, 2013 at 11:09 PM, nicolas bozon <
>> >>> Hello Anunay and welcome to this list.
>> >>> I think you did a great choice for your 'web based GIS system',
>> because WPS can handle pretty much things for it.
>> >>> As far as i know, there are 5 open source WPS platforms out there,
>> but GeoTools isn't one (although it is used by GeoServer). Your list would
>> then become, by alphabetical order:
>> >>> 1. Degree
>> >>> 2. GeoServer
>> >>> 3. PyWPS
>> >>> 4. ZooWPS
>> >>> 5. 52North
>> >>> They are all implementing the WPS specification from OGC and they are
>> all open source.
>> >>> I guess they are all able to run GIS algorithms available from other
>> open source libraries such as GDAL, GRASS, Sextante, GeoTools,
>> Sextante...,using different methods.
>> >>> Most of them are written in Java or Python, but ZOO-Kernel
>> (ZOO-Project engine) is written in C language.
>> >>> This somehow allows him to execute WPS Services coded in different
>> languages (C, Python, Java, JavaScript...), so you won't be limited to only
>> Java or Python. It can open doors to 'any' source code you want to turn
>> into a compliant Web Service.
>> >>> This is my simple ZOOer answer, but i would recommend you post such a
>> generic question to wps-dev at lists.opengeospatial.org, so you would
>> probably get more answers from the different projects developers and users.
>> >>> Good luck and feel free to ask more questions on this list too.
>> >>> Best regards,
>> >>> Nick
>> >>> We have a requirement where in we need to expose our analysis to a
>> web based GIS system. We decided to do it using WPS.
>> >>> However I have general question about WPS (This may not be the best
>> platform but still.)
>> >>> What is a difference between different WPS Frameworks out there
>> >>> 1. GeoServer
>> >>> 2. GeoTools
>> >>> 3. Deegree
>> >>> 4 52North
>> >>> 5 ZooWPS
>> >>> I am not sure which one to choose and what are things I need to
>> consider when making this choice.
>> >>> Also if you can let me know where ZooWPS stands when compared with
>> the rest (My thinking here is since they all provide OGC WPS Implementation
>> they all should be doing pretty much the same thing, but that is a wild
>> thought)
>> >>> Looking for your help
>> >>> Anunay
>> >>> _______________________________________________
>> >>> Zoo-discuss mailing list
>> >>> Zoo-discuss at lists.osgeo.org
>> >>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
>> >> Gérald Fenoy
>> > Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20131129/f24c21f6/attachment-0001.html>
More information about the Zoo-discuss mailing list
