[Zoo-discuss] POST not implemented
Fenoy Gerald gerald.fenoy at geolabs.fr
Sat Aug 2 08:33:02 PDT 2014
Dear Pablo,
I would like to know what is the ZOO-Kernel version you are currently using ?
Indeed it sounds strange that switching from GET to POST change so much thing. In other case, this have to be review and fixed asap.
So, I would like to invite you to build the ZOO-Kernel from the SVN trunk source tree and try the same requests against this version and report any issue if you have still one.
I hope to hear back from you,
Best regards,
Le 30 juil. 2014 à 18:24, pablo zader <pzader at gmail.com> a écrit :
> Thanks Fenoy
> I am now using as input appliaction/xml instead of text/xml and it works!! (through POST . attach in this mail). But I have another error (attach the log file zoo_proyect):
> TRACE : GDLA error while import. Unable to create input location from input /tmp/tmphfAPH3/input_0 GDAL log: ERROR: Unable to open data source </tmp/tmphfAPH3/input_0><class 'gms.ErrorHandler.GMSError'>Unable to run your python process properly. Please check the following messages : [' File "/usr/lib/cgi-bin/v_buffer.py", line 7, in v_buffer\n service.fromMaps("v.buffer", inputs, outputs)\n', ' File "/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 77, in fromMaps\n self._importData()\n', ' File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 469, in _importData\n self._createInputLocation(input)\n', ' File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 568, in _createInputLocation\n raise GMSError(log)\n']
> But making a GET request works well:
> http://localhost/cgi-bin/zoo_loader.cgi?request=Execute&service=WPS&version=1.0.0&Identifier=v_buffer&DataInputs=input=Reference@xlink:href=http%3A%2F%2Flocalhost%2Fcgi-bin%2Fmapserv%3Fmap%3D%2Fvar%2Fwww%2Fmapfile%2Fwfs.map%26SERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dfeature%3Acontinent%26SRS%3DEPSG%3A4326%26FeatureID%3Dcontinent.1;distance=10&RawDataOutput=output@mimeType=application/xml
> Another test was made ​​using cURL where the file demo1.xml  containing the above information request POST:
> curl -H "Content-Type: application/xml" -d@/home/pablo/Descargas/demo1.xml "http://localhost/cgi-bin/zoo_loader.cgi"
> <?xml version="1.0" encoding="utf-8"?>
> <ExceptionReport xmlns="http://www.opengis.net/ows/1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd" xml:lang="en-US" version="1.1.0">
>   <Exception exceptionCode="NoApplicableCode">
>     <ExceptionText>TRACE : GDLA error while import. Unable to create input location from input /tmp/tmpitl1aH/input_0 GDAL log: ERROR: Unable to open data source </tmp/tmpitl1aH/input_0>
> Unable to run your python process properly. Please check the following messages : ['  File "/usr/lib/cgi-bin/v_buffer.py", line 7, in v_buffer\n    service.fromMaps("v.buffer", inputs, outputs)\n', '  File "/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 77, in fromMaps\n    self._importData()\n', '  File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 469, in _importData\n    self._createInputLocation(input)\n', '  File "/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 568, in _createInputLocation\n    raise GMSError(log)\n']</ExceptionText>
>   </Exception>
> </ExceptionReport>
> Note:
> The get request was made on a vector taken with WFS
> The POST request is on a user-selected feature from the map.
> Thanks in advanced
> Pablo
> 2014-07-28 12:17 GMT-03:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> Dear Pablo,
> thanks for providing your XML request.
> From my point of view, there is an issue in the request you provided, you defined the mimeType attribute of your ComplexeData node to « text/xml » which is valid, but then, rather than providing a XML node in the request, you provided a CDATA node which should be used for ComplexData with the mimeType defined to application/json for instance.
> In the case of mimeType defined to text/xml, the ZOO-Kernel is searching for a XML node which will be used as a root of a new document which will then be used to POST the request to the targeted server.
> So your request should work by removing both: «  <![CDATA[ » and « ]]> » from its content.
> If anybody think that it is wrong to handle the text/xml content the way ZOO-Project is doing, then please speak up and let me know.
> I wonder, cause it is not the first time that somebody send such kind of requests. The issue Steve faced with his request was really similar to this one.
> We may fix the issue directly in the Client code maybe ?
> Waiting for your answer,
> Best regards,
> Le 28 juil. 2014 à 16:27, pablo zader <pzader at gmail.com> a écrit :
> > Hi list,
> > I'm developing a client wps modifying the example WPSDemo.js from
> > http://suite.opengeo.org/4.1/processing/wpsclient/index.html .
> > I'm using zoo-proyect as wps server.
> > I'm trying to invoke the buffer process implemented in GRASS GIS gives me the following error:
> > POST http://localhost:9080/proxy/?url=http%3A%2F%2Flocalhost%2Fcgi-bin%2Fzoo_loader.cgi%3F 501 (Not Implemented)
> > The query POST is:
> > <wps:Execute xmlns:wps="http://www.opengis.net/wps/1.0.0" version="1.0.0" service="WPS" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">v_buffer</ows:Identifier><wps:DataInputs><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">input</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Or data source for direct OGR access</ows:Title><wps:Data><wps:ComplexData mimeType="text/xml"><![CDATA[<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs"><gml:featureMember xmlns:gml="http://www.opengis.net/gml"><feature:features xmlns:feature="http://mapserver.gis.umn.edu/mapserver" fid="OpenLayers_Feature_Vector_248"><feature:geometry><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates decimal="." cs="," ts=" ">-6383273.5489707,1396657.4552779 -4230806.8327598,26905.908598173 -6246298.3943028,-442723.19312058 -6383273.5489707,1396657.4552779</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></feature:geometry></feature:features></gml:featureMember></wfs:FeatureCollection>]]></wps:ComplexData></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">layer</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name.</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">cats</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Example: 1,3,7-9,13</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">where</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Example: income  1000 and inhab :: 10000</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">type</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Feature type</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">distance</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Buffer distance along major axis in map units</ows:Title><wps:Data><wps:LiteralData>195678.7923828125</wps:LiteralData></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">minordistance</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Buffer distance along minor axis in map units</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">angle</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Angle of major axis in degrees</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">bufcolumn</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Name of column to use for buffer distances</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">scale</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Scaling factor for attribute column values</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">tolerance</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Maximum distance between theoretical arc and polygon segments as multiple of buffer</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">-s</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Make outside corners straight</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">-c</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Dont make caps at the ends of polylines</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">-t</ows:Identifier><ows:Title xmlns:ows="http://www.opengis.net/ows/1.1">Transfer categories and attributes</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input></wps:DataInputs><wps:ResponseForm><wps:RawDataOutput mimeType="text/xml"><ows:Identifier xmlns:ows="http://www.opengis.net/ows/1.1">output</ows:Identifier></wps:RawDataOutput></wps:ResponseForm></wps:Execute>
> > Thanks in advanced
> > P.
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
> Pablo J. Zader
> Lic. en Cs. de la Computación
> CONAE
> pablo.zader at gmail.com
> "Los Grandes Hombres hablan sobre ideas...
>  Los Hombres Promedio hablan sobre cosas...
>  Los Hombres Pequeños hablan.. de otros Hombres.
> del libro Matemática estas ahi? A. Paenza "
> <log_zoo.txt><demo1.xml>
Gérald Fenoy
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140802/b16bdd21/attachment.pgp>
More information about the Zoo-discuss mailing list
