[Zoo-discuss] WPS Execute request - POST reference
Alexandre Dubé
adube at mapgears.com
Fri Aug 29 07:27:12 PDT 2014
Hi Nicolas,
Thanks for the answer. So, this means there's something wrong with
my execute XML, then. Please, let me know if I got this straight:
The process I'm trying is: Boundary. See its description:
http://zoo-project.org/cgi-bin-new1/zoo_loader.cgi?SERVICE=WPS&VERSION=1.0.0&REQUEST=DescribeProcess&IDENTIFIER=Boundary
So, the only input it supports is : "InputPolygon", which support the
'text/xml' MimeType. The Reference node I use in my execute query looks
like this:
<wps:Reference mimeType="text/xml; subtype=wfs-collection/1.1" xlink:href="http://dev8.mapgears.com/cgi-bin/tinyows-trunk" method="POST">
So, basically the mimeType seems okay, right ? I tried adding the
Header node before the Body, but I still get the same error: "Unable to
parse Input Polygon". I don't have much knowledge of this, so I'm
pretty much trying/guessing things...
Does this process support a WFS GetFeature request as input ? If it
does, do you have more hints why my request doesn't work ?
Thank you very much,
Alexandre
On 14-08-29 09:42 AM, nicolas bozon wrote:
> Hi Alexandre,
> Yes, POST is supported. Here is an example, with header and body
> specified:
> https://github.com/WPS-Benchmarking/cptesting/blob/master/requests/irb2_o.xml
> (Please have a look from line 7 to 11)
> Hope it helps.
> Best,
> Nick
> 2014-08-27 15:22 GMT+02:00 Alexandre Dubé <adube at mapgears.com
> <mailto:adube at mapgears.com>>:
> Hi list,
> In summary
> Does Zoo support wps:Reference node using method="POST" ?
> Details
> It will be easier to explain using examples. See the attached
> files. Using curl, you can easily execute the requests and see
> the first one working (method=GET) and the other doesn't
> (method=POST). The latter seems to be correctly set (the XML
> seems okay). So I'm not sure where the problem
> is. Does Zoo support wps:Reference node using method="POST" or is
> there something wrong with my XML definition ?
> GET:
> curl -X POST -d @execute-wfs5-get-custom.xmlhttp://zoo-project.org/cgi-bin-new1/zoo_loader.cgi --header "Content-Type:text/xml"
> POST:
> curl -X POST -d @execute-wfs4-post-custom.xmlhttp://zoo-project.org/cgi-bin-new1/zoo_loader.cgi --header "Content-Type:text/xml"
> Any hint ?
> Alexandre Dubé
> T:+1 418-696-5056 #203 <tel:%2B1%20418-696-5056%20%23203>
> http://www.mapgears.com/
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org <mailto:Zoo-discuss at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Alexandre Dubé
T: +1 418-696-5056 #203
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140829/b57aac66/attachment.html>
More information about the Zoo-discuss
