[Zoo-discuss] Python service doesn't see Environment variable
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Thu Dec 18 05:33:35 PST 2014
Thanks for your answer Gerald and for this: conf["main"]["tmpDir"]
I will use it instead of the environment variable
Steve
Fenoy Gerald <gerald.fenoy at geolabs.fr>
2014-12-18 02:24
A
cc
ZOO-discuss <zoo-discuss at lists.osgeo.org>
Objet
Re: [Zoo-discuss] Python service doesn't see Environment variable
Dear Steve,
for defining environment variables prior to run your service you should
use a specific section in your main.cfg file. This section should be named
[env] then you can define any key value pair, so for defining tmpdir as an
environment variable you simply have to add the following to your
main.cfg:
[env]
TMPDIR=/your/tmp/dir
Obviously you should replace « /your/tmp/dir » by a real path.
Please also note that there is already a default tmpdir variable but it is
not defined as an environment variable but can be accessed easilly from
any service. It is located in the [main] section and is named tmpDir. So
to access it from your service code you may use something like :
conf["main"]["tmpDir"] .
I hope this helps,
Best regards,
> Le 17 déc. 2014 à 20:21, Steve.Toutant at inspq.qc.ca a écrit :
> I want my python process to access some environment variables
> in a console launching this command works
> python -c 'import os; print os.environ["TMPDIR"]'
> But when zoo execute the python process it returns an error. Same using
getenv()
> To create the environment variable I created a .sh in /etc/profile.d/
> and it contains export TMPDIR="/tmp"
> How can I fix this please?
> thanks
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20141218/62bf91f3/attachment.html>
More information about the Zoo-discuss mailing list
