[Zoo-discuss] ZOO and Mapserver 6.4
Luca Delucchi lucadeluge at gmail.com
Tue Jan 14 01:35:00 PST 2014
On 19 December 2013 11:08, Fenoy Gerald <gerald.fenoy at geolabs.fr> wrote:
> Hi Luca,
Hi Gerald,
> nice to hear that you are trying to use the MapServer support with the 6.4.0 version. I never tried it before as I’m mainly using 6.2.0 version by now.
> Nevertheless, I successfully link the ZOO-Kernel against a fresh MapServer 6.4.0 build on MacOS X by using the patch attached to this email.
> I hope it helps and will work for you.
I patched with
patch -p0 < mapserver.patch
but I obtain this problem during configure
checking for xmlInitParser in -lxml2... yes
./configure: line 5503:
/home/lucadelu/compilati/mapserver-6-4-1/mapserver-config: No such
file or directory
./configure: line 5504:
file or directory
file or directory
Using user-specified MapServer src path:
and this during compilation
g++ -I/include -I/include -I/usr/local/include -fpic  -DUSE_MS
-I/home/lucadelu/compilati/mapserver-6-4-1  -I../../thirds/cgic206 -I.
-DLINUX_FREE_ISSUE  -c lex.cr.c
gcc -DUSE_JS -I/usr/include/js/ -I/usr/include/libxml2 -I/include
-DLINUX_FREE_ISSUE  -fPIC -c service_internal.c
In file included from service_internal_ms.h:41:0,
                 from service_internal.c:27:
/home/lucadelu/compilati/mapserver-6-4-1/mapserver.h:32:30: fatal
error: mapserver-config.h: No such file or directory
 #include "mapserver-config.h"
compilation terminated.
make: *** [service_internal.o] Error 1
> Note that I didn’t tried to use the support once compiled as I get the mapserver-6.2.0 library setup already. But I would appreciate to hear from your tests using this MapServer version.
> Hop ego hear back from you,
> Best regards,
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss mailing list
