[Zoo-discuss] mimeType output
Fenoy Gerald gerald.fenoy at geolabs.fr
Thu Jan 16 08:22:04 PST 2014
Dear Quang,
I’m not sure to understand exactly what you are searching for.
ZOO-Kernel should be able to handle any kind of mimeType « as-is ». In some cases, for instance when you are asking for the ZOO-Kernel to store your result, the name of the stored file won’t have any relation with the mimeType you specified. You can see here how it works : [1] and how mimeType are used to define extension in the filename stored.
To simplify we may add an array or a map in service.h storing couples of (mimeType,extension)  or we may also use extension defined in zcfg file.
Anyway, first I would like to make I am on the right way for your question about integrating a new mimeType support.
Best regards,
[1] http://zoo-project.org/trac/browser/trunk/zoo-project/zoo-kernel/service_internal.c#L1937
Le 16 janv. 2014 à 11:52, truongxuan quang <truongxuanquang at yahoo.com> a écrit :
> If I use xsd or xslt in this case it is fine with ZOO-kernel?
> On Thursday, January 16, 2014 11:48 AM, truongxuan quang <truongxuanquang at yahoo.com> wrote:
> Dear list
> It is possible if I would like to define my mineType for ComplexOutput in ZOO-Project, If yes how can I config for a new mineType.
> Many thanks,
> T.Xuan Quang
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140116/de8415d9/attachment.pgp>
More information about the Zoo-discuss mailing list
