[Zoo-discuss] don't find the directory zoows in OSGeolive
Fenoy Gerald gerald.fenoy at geolabs.fr
Sat Jul 19 12:36:06 PDT 2014
Dear lamiaa,
thanks a lot for giving a try to this workshop.
I would like first to inform you that I would recommend that you may try using the 2013 workshop which is more simple for a first approach than the old 2010 one. In the 2010 workshop we were willing to present both C and Python version of services but maybe trying using C code as a first try may make the learning more difficult I think.
Furthermore you may face issue (not when running the workshop material but using the 2010 ZOO-Kernel version) specifics to this version which is not much used nowadays.
So I would recommend that you use this workshop [1].
Once you have the 2013 ZOO-Project Workshop running on your virtual machine, then if you want to learn how to code C services you can then go back to the 2010 Workshop material. I think it’s better this way.
Hope this helps and convince you,
Best regards,
[1] http://zoo-project.org/docs/workshop/2013/index.html
Le 19 juil. 2014 à 20:01, lamiaa khazaz <lamiaa.perso at gmail.com> a écrit :
> Hello
> i'm trying to do the workshop 2010 for Zoo project, using the OSGeoLive virtual machine.
> The test of zoo project is working perfectly but i don't find the directory:
>  /home/user/zoows
> i tried cd ~/zoows  the answer is "no such file or directory"
> thank you
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20140719/d3926ab5/attachment.pgp>
More information about the Zoo-discuss mailing list
