[Zoo-discuss] java service example 2
andrea antonello andrea.antonello at gmail.com
Mon Nov 17 04:41:45 PST 2014
Hi Gerald,
> I confirm that the initial issue was correct. In this file [1] we can see on line 11 and 12 that you are expecting to access the value of
> an input directly by accessing it using its name. Nevertheless, it is the same structure as the one used in other languages, so in
> Java it will be HashMap of HashMap of String rather than simply HashMap of String. So when you use the following,it will return a HashMap:
> As I used the same variable names, I guess this should work after applying this correction to the source code.
> I hope this solve the issue and you can confirm that this fix work for the service.
I now get the problem in the syntax. I did the changes in the example.
I still get a jvm crash.
Can you double-check the syntax please? It should really be ok now.
> [1] https://github.com/moovida/zoo-java-example-service/blob/master/ZooJavaMain/src/org/jgrasstools/ZooJavaWps.java
Another question: is the part:
  outputOutPathMap.put("dataType", "string");
necessary for the outputs?
And will the same be always available in the input hashmaps? This
might be helpful to check on the inputs before processing?
Thanks,
Andrea
>> Le 14 nov. 2014 à 10:43, andrea antonello <andrea.antonello at gmail.com> a écrit :
>> Hi Gerald,
>> I am starting a new thread on this, in order to not pollute the old one.
>> I have created a github project with the example java service:
>> I also put there all the documentation (readme) of what is inside and
>> how to create the necessary jars and dependencies.
>> I tried to make this work directly in zoo, but there are errors that
>> don't seem to be pertinent and I have no idea about how to get
>> something more precise out of it.
>> It would be great if you could find the time to run this and we can
>> then fix the project to make it properly work on zoo.
>> Let me know what you think.
>> Thanks,
>> Andrea
>> Zoo-discuss mailing list
>> Zoo-discuss at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
