[Zoo-discuss] C process fail after 60 seconds
Fenoy Gerald
gerald.fenoy at geolabs.fr
Fri Apr 10 15:21:55 PDT 2015
Dear Steve,
I do apologize for answering your email so late.
The issue you faced probably came from the ZOO-Kernel. I noticed similar issues when trying to use Execute requests with more than one inputs from revision 550 [1] to revision 621 [2]. Nevertheless, the issue I found is now fixed in revision 621 and upper. In revision 550, we added some code to handle correctly the order of downloaded files for input supporting multiple values. This solved the issue.
I hope you can try with the latest SVN version and confirm that it solves your issue.
In case it still fail, please let us know and we will have a deeper look.
Best regards,
[1] http://zoo-project.org/trac/changeset/550/trunk/zoo-project/zoo-kernel/service_internal.c
[2] http://zoo-project.org/trac/changeset/621/trunk/zoo-project/zoo-kernel/service_internal.c
> Le 2 avr. 2015 à 18:48, Steve.Toutant at inspq.qc.ca a écrit :
> the 1 minute timeout is just a coincidence. I tried with another layer and it fails with the same error at 2.5 minutes.
> So the problem might be in the service, with ogr...?
> I have no idea on how to debug this
> Any help will be appreciated
> thanks
> steve
> Steve Toutant, M. Sc.
> Analyste en géomatique
> Secteur environnement
> Direction de la santé environnementale et de la toxicologie
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc, G1V 5B3
> Tél: 418 654-3010 poste 5428
> Téléc: 418 644-4593
> http://www.inspq.qc.ca
> http://www.monclimatmasante.qc.ca
> Steve.Toutant at inspq.qc.ca@lists.osgeo.org
> Envoyé par : zoo-discuss-bounces at lists.osgeo.org
> 2015-04-02 12:19
> A
> Fenoy Gerald <gerald.fenoy at geolabs.fr>
> cc
> ZOO-discuss <zoo-discuss at lists.osgeo.org>
> Objet
> Re: [Zoo-discuss] C process fail after 60 seconds
> htop tells me that memory and cpu are fine, no swap.
> But when zoo stops, I see that mapserv is still running.
> It seems that zoo is waiting for the wfs featurecollection that never comes after 1 minute and zoo stops.
> Is there a zoo or apache config that can be used to tell zoo to wait longer?
> thanks
> steve
> 2015-04-01 16:39
> A
> cc
> Objet
> Hi Steve,
> I am not sure to understand clearly the situation. Nevertheless, I don’t think this can come from Apache.
> Maybe there is some issue with the C services you are using ?
> I hope to hear back from you and we can fix your issue,
> Best regards,
> > Le 1 avr. 2015 à 21:45, Steve.Toutant at inspq.qc.ca a écrit :
> > i get this error for a C service after it is running more than a minute
> > <Exception exceptionCode="InternalError">
> > <ExceptionText>ZOO Kernel failed to process your request receiving signal 11 = SIGSEGV</ExceptionText>
> > </Exception>
> > Coud it be an apache or cgi config?
> > I set TimeOut 3600 in apache config and restart the server but still have this error.
> > thanks_______________________________________________
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
Gérald Fenoy
More information about the Zoo-discuss
