[Zoo-discuss] Getting error when working with IIS
Fenoy Gerald gerald.fenoy at geolabs.fr
Thu Jul 2 04:48:41 PDT 2015
Hello,
sorry for late reply.
I just committed the updated documentation for building the ZOO-Project on windows platforms [1].
In the online documentation, you should find all the required and optional settings you can do in the name.opt file [2].
Nevertheless, building ZOO-Kernel on windows will require you to build all the libraries the ZOO-Kernel depends on.
Please refer to [3] and make sure you build all the mandatory dependencies.
I hope it will help you in building the ZOO-Kernel on your windows platform.
Best regards,
[1] http://zoo-project.org/trac/changeset/722
[2] http://zoo-project.org/docnew/docs/_build/html/install/windows.html#build-options
[3] http://zoo-project.org/docnew/docs/_build/html/install/prerequisites.html#mandatory
> Le 2 juil. 2015 à 07:03, Pankaj Pedram <pankaj.pedram at rolta.com> a écrit :
> Hello Fenoy,
> Greetings!!!
> Did you get any solution? I am still not able to compile and configure  Zoo kernel on Windows 7 Machine (64 Bit), IIS 7.5 and Visual Studio Command prompt 2010.
> Mean while I tried to configure with Python 2.7 it is giving me error regarding libs.obj missing. I have installed Python 2.7 through a setup which did not create any such file in C:\Python27\Lib directory.
> It will be really helpful for me if you could provide any solution as soon as possible.
> Regards,
> Pankaj
> -----Original Message----- From: Pankaj Pedram
> Sent: Monday, June 29, 2015 6:21 PM
> To: Fenoy Gerald
> Cc: ZOO-discuss
> Subject: Re: [Zoo-discuss] Getting error when working with IIS
> Hello Fenoy,
>   Thanks for your response.
>   I have configured the paths in nmake.opt file itself, still I am getting
> same error.
>   Please find the attached file(nmake.opt)
>   Hope I will be able configure zoo project soon in IIS .
> Regards,
> Pankaj
> -----Original Message----- From: Fenoy Gerald
> Sent: Friday, June 26, 2015 4:22 PM
> To: Pankaj Pedram
> Cc: ZOO-discuss
> Hello,
> when building ZOO-Kernel on windows platforms you should define some options
> on the command line.
> Some are optional but some are not, like libxml2, openssl, goal and so on.
> That is why you end with the following reference:
> D:\ZooProject\Zoo680\zoo-project\zoo-kernel\ssl/ssleay32.lib
> Which means that you did not define the SSL_DIR.
> You will require to define also GDAL_DIR, INTL_DIR and XML2_DIR as a
> minimum.
> You may check the name.opt file in the zoo-kernel directory to see available
> and required options.
> For optional support, such as Python, you can simply define PY_DIR to
> activate it.
> To define those options you can use the « set » command or define the values
> directly from the command line, something like:
> nmake /f makefile.vc GDAL_DIR=\MMBK\SRCS\gdal-version
> SSL_DIR=\MMBK\SRCS\openssl
> I hope it will help you to solve your compilation issue.
> Best regards,
>> Le 26 juin 2015 à 12:00, Pankaj Pedram <pankaj.pedram at rolta.com> a écrit :
>> Hello Fenoy,
>> I tried to compile the zoo kernel, but got following error  for both
>> Visual Studio command prompt 2008 and Visual Studio command prompt 2010:
>> D:\ZooProject\Zoo680\zoo-project\zoo-kernel>nmake /f makefile.vc
>> Microsoft (R) Program Maintenance Utility Version 9.00.30729.01
>> Copyright (C) Microsoft Corporation.  All rights reserved.
>>      link zoo_loader.obj request_parser.obj response_print.obj
>> server_internal.obj caching.obj      ulinet.obj main_conf_r
>> ead.tab.obj lex.cr.obj service_conf.tab.obj lex.sr.obj
>> zoo_service_loader.obj ./libzoo_service.lib /out:zoo_loader.cgi D:\Zo
>> oProject\fcgi-2.4.1-SNAP-0311112127/libfcgi/Release/libfcgi.lib
>> D:\ZooProject\Zoo680\zoo-project\zoo-kernel\ssl/libeay32.l
>> ib  D:\ZooProject\Zoo680\zoo-project\zoo-kernel\ssl/ssleay32.lib
>> D:\ZooProject\Zoo680\zoo-project\zoo-kernel\intl/libintl.li
>> b D:\ZooProject\Zoo680\zoo-project\zoo-kernel\libxml/libxml2.lib
>> D:\ZooProject\Zoo680\zoo-project\zoo-kernel\gdal\lib/gdal_i.
>> lib D:\ZooProject\Zoo680\zoo-project\zoo-kernel\curl/lib/libcurl.lib
>> /machine:i386 ./../../thirds/cgic206/libcgic.lib
>> Microsoft (R) Incremental Linker Version 9.00.30729.01
>> Creating library zoo_loader.lib and object zoo_loader.exp
>> server_internal.obj : error LNK2019: unresolved external symbol
>> _BIO_free_all referenced in function _base64
>> server_internal.obj : error LNK2019: unresolved external symbol _BIO_ctrl
>> server_internal.obj : error LNK2019: unresolved external symbol _BIO_write
>> server_internal.obj : error LNK2019: unresolved external symbol _BIO_push
>> server_internal.obj : error LNK2019: unresolved external symbol _BIO_s_mem
>> _BIO_set_flags referenced in function _base64
>> server_internal.obj : error LNK2019: unresolved external symbol _BIO_new
>> _BIO_f_base64 referenced in function _base64
>> server_internal.obj : error LNK2019: unresolved external symbol _BIO_read
>> referenced in function _base64d
>> _BIO_new_mem_buf referenced in function _base64d
>> caching.obj : error LNK2019: unresolved external symbol
>> _EVP_MD_CTX_cleanup referenced in function "char * __cdecl getMd5(cha
>> r *)" (?getMd5@@YAPADPAD at Z)
>> _EVP_DigestFinal_ex referenced in function "char * __cdecl getMd5(cha
>> caching.obj : error LNK2019: unresolved external symbol _EVP_DigestUpdate
>> referenced in function "char * __cdecl getMd5(char
>> caching.obj : error LNK2019: unresolved external symbol _EVP_DigestInit
>> referenced in function "char * __cdecl getMd5(char *)
>> caching.obj : error LNK2019: unresolved external symbol _EVP_md5
>> referenced in function "char * __cdecl getMd5(char *)" (?get
>> Md5@@YAPADPAD at Z)
>> zoo_loader.cgi : fatal error LNK1120: 15 unresolved externals
>> NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
>> Studio 9.0\VC\BIN\link.EXE"' : return code '0x460'
>> Stop.
>> Kindly help me to solve the issue as soon as possible.
>> Thanking you in anticipation.
>> Regards,
>> Pankaj Pedram
>> Sent: Thursday, June 25, 2015 6:05 PM
>> To: Pankaj Pedram
>> Cc: ZOO-discuss
>> Hello Pankaj,
>> thanks a lot for your feedbacks and congratulations for building the
>> ZOO-Kernel on your windows system.
>> I would like to make sure you are using the right version of the code to
>> build.  First of all, can you confirm that you have generated both the
>> zoo_loader.cgi and the libzoo_service.dll files ? I start by asking this
>> question, cause when I run the zoo_loader.cgi command locally, I get two
>> Exception nodes, so one more than the ExceptionReport you reported. The
>> first one is the exact same as your's but the second reference the service
>> locator. In case you are not using the latest trunk version, I would like
>> to invite you to try with the revision 680 [1]. If you have both
>> zoo_loader.cgi and the libzoo_service.dll generated, please make sure to
>> copy both of them to your cgi-bin directory.
>> After making sure you are using the latest ZOO-Kernel version, you should
>> take a look at your main.cfg file. Indeed, a specific logPath parameter is
>> required in the [main] section of the main.cfg file to run on IIS server
>> properly. This parameter should take the full path of a log file used to
>> output any debug messages. Other parameters of the main.cfg should be also
>> correctly defined but for a simple GetCapabilities request, defining the
>> logPath should be enough. You should obviously make sure that the IIS user
>> is allowed to write the log file.
>> I hope this answer will help to solve your issue,
>> Best regards,
>> [1] http://zoo-project.org/trac/changeset/680
>>> Le 25 juin 2015 à 07:55, Pankaj Pedram <pankaj.pedram at rolta.com> a écrit
>>> Hi,
>>> Greetings!!!
>>> I have been trying to Install zoo kernel on IIS.
>>> I was able to compile the zoo kernel and was able generate the
>>> zoo_loader.cgi file.
>>> I placed the  zoo_loader.cgi and main.cfg file(modified the
>>> ServerAddress ) in  C:\inetpub\wwwroot\cgi-bin
>>> Then through the command prompt I was able to generate same response as
>>> we get by installing Apache Server.
>>> I got the response as below :
>>> c:\inetpub\wwwroot\cgi-bin>zoo_loader.cgi
>>> Content-Type: text/xml; charset=utf-8
>>> Status: 400 Bad request
>>> <?xml version="1.0" encoding="utf-8"?>
>>> <ExceptionReport xmlns="http://www.opengis.net/ows/1.1"
>>> xmlns:xsi="http://www.w3
>>> .org/2001/XMLSchema-instance"
>>> xsi:schemaLocation="http://www.opengis.net/ows/1.1
>>> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
>>> xml:lang="en-US" v
>>> ersion="1.1.0">
>>> <Exception exceptionCode="MissingParameterValue" locator="request">
>>>   <ExceptionText>Parameter <request> was not
>>> specified</ExceptionText>
>>> </Exception>
>>> </ExceptionReport>
>>> But when I try to access through browser
>>> (http://localhost/cgi-bin/zoo_loader.cgi?Service=WPS&Request=GetCapabilities&Version=1.0.0)
>>> I get error as :
>>> HTTP Error 502.2 - Bad Gateway
>>> The specified CGI application misbehaved by not returning a complete set
>>> of HTTP headers. The headers it did return are "".
>>> It will be helpful for me if you could help me out with tis issue.
>>> Regards,
>>> Pankaj Pedram
>>> 07506934293
>>> pankaj.p.pedram at gmail.com
>>> Zoo-discuss mailing list
>>> Zoo-discuss at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
>> Gérald Fenoy
>> http://wiki.osgeo.org/wiki/User:Djay
> Gérald Fenoy
Gérald Fenoy
More information about the Zoo-discuss mailing list
