[Zoo-discuss] ZOO-Project 1.5.0 release
Venkatesh Raghavan venka.osgeo at gmail.com
Fri Jul 10 08:36:27 PDT 2015
Hi Gerald,
Great to hear about the Z00-1.5.0 release.
Hope you have a great presentation at
FOSS4G-Europe in Como.
Best
Venka
On 2015/07/10 22:20, Fenoy Gerald wrote:
> Dear all,
> as release manager, I am glad to announce the publication the ZOO-Project-1.5.0.
> The release can be downloaded from the download page [1], or by using the direct links to download in zip format [2] or in tar.bz2 [3].
> The new release includes the following changes and bug fixes :
> * Complete rewrite of the documentation to use modern style
> * Fix asynchronous POST request on WIN32 platforms
> * Add utils/registry service
> * Initial support for WPS 2.0.0 including the Dismiss extension
> * Fix concurrency access to status informations
> * Use simple file rather than shared memory for storing status informations
> * Add support for db backend to store status informations
> * Add the lib_zoo_service shared library to be linked against C services
> * Add ZOO-API for the PHP language (with documentation)
> * Add doxygen comments in source code
> * Add support for multiple Exception nodes
> * Add a length key when creating MapArray
> * Add OTB support for applications as a service
> * Add the otb2zcfg utility to produce zcfg for otb applications
> * Add OTB Application Observer to have progress status updates
> * Fix maxOccurs handling
> * Fix gesture of downloaded inputs when multiple values are given
> * Add detection of generated_file key in outputs to read the file
> generated by a service
> * Add a minimal parsing API
> * Run validateRequest (download, default settings and decoding)
> after fork if any
> * Add SAGA-GIS support for modules as a service
> * Add saga2zcfg utility to generate zcfg for SAGA-GIS modules
> * Add SAGA-GIS Observer to have ongoing status updates
> This work was supported by a grant from the European Union's 7th Framework Programme (2007-2013) provided for the project PublicaMundi (GA no. 609608).
> I hope we can all test and report any important bug found in this release.
> Best regards,
> [1] http://zoo-project.org/trac/wiki/Downloads#ZOO-Projectversion1.5.0
> [2] http://zoo-project.org/dl/zoo-project-1.5.0.zip
> [3] http://zoo-project.org/dl/zoo-project-1.5.0.tar.bz2
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
More information about the Zoo-discuss mailing list
