[Zoo-discuss] Help on Installation zoo-kernel Lubuntu
Fenoy Gerald gerald.fenoy at geolabs.fr
Mon Jul 27 03:02:47 PDT 2015
Hi Lorenzo,
can you tell me what is the version of ZOO-Project you are using ?
Indeed, if you look into the 1.5.0 release, you should not have any message about libgeos anymore in such a situation as it should now be well spelled as you can see here [1]. So, I suppose that you are using an older version of the ZOO-Kernel or that you did not run autoconf in the ZOO-Kernel source directory which leads to use an old configure script. I would like to invite you to try the latest 1.5.0 version and try to build this version which should solve this issue.
For building the ZOO-Kernel internal MapServer support you will require to have a compiled version of MapServer-6.2.0 which contained the mapserver-config tool required. Note that, even if mapserver-config is used to fetch the MapServer compilation options it won’t be required at runtime, so if you have a similar configuration for 6.4.1 and 6.2.0 version then you can use the 6.4.1 version at runtime. So your ZOO-Kernel will use MapServer 6.4.1 even if it was build using the MapServer 6.2.0 configuration options.
I hope this help you to solve your issue,
Best regards,
[1] http://zoo-project.org/trac/browser/branches/branch-1.5/zoo-project/zoo-kernel/configure.ac#L318
> Le 24 juil. 2015 à 12:15, Lorenzo Bottaccioli <lorenzo.bottaccioli at gmail.com> a écrit :
> Hi, I'm trying to install zoo-project on Lubuntu. I cannot perform the installation. I recive erros after code: ./configure --with-pyvers=2.7 --with-js --with-mapserver=/home/lorenzo/mapserver-6.4.1
> Response : checking for geos_c.h... yes
> checking CGAL/Delaunay_triangulation_2.h usability... no
> checking CGAL/Delaunay_triangulation_2.h presence... no
> checking for CGAL/Delaunay_triangulation_2.h... no
> configure: WARNING: could not find headers include related to libgeos
> ./configure: line 5906: /home/lorenzo/mapserver-6.4.1/mapserver-config: No such file or directory
> ./configure: line 5907: /home/lorenzo/mapserver-6.4.1/mapserver-config: No such file or directory
> Using user-specified MapServer src path: /home/lorenzo/mapserver-6.4.1
> checking for JS_CompileFile,JS_CallFunctionName in -lmozjs185... yes
> configure: creating ./config.status
> config.status: creating Makefile
> config.status: creating ZOOMakefile.opts
> If I remove the --with-mapserver I avoid the error but still it remains the problem with libgeos that is installed.
> If I do make after it give a log list of errors.
> How do I fix this?
> Tnx
> Lorenzo
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
