[Zoo-discuss] Problems with service
Luca Delucchi lucadeluge at gmail.com
Tue Jul 28 07:06:37 PDT 2015
On 28 July 2015 at 14:58, Fenoy Gerald <gerald.fenoy at geolabs.fr> wrote:
> Hi Luca,
Hi gerald,
> sorry I did not take attention of the second issue you mentioned.
> Nevertheless, I give it a short try. Not directly by using your service code but by using a simpler one, just to see if something strange happened.
> So, I’ve used the test_service.py from hello-py zoo-services directory and added a simple       geopaposm service which looks exactly like the following:
> def geopaposm(conf,inputs,outputs):
>         outputs["result"]["value"]=inputs["inputvector"]["value"]
>         return zoo.SERVICE_SUCCEEDED
> (Luca, you should be able to use the same zcfg file than the one you used before.)
> So, I requested using your request (which corresponds to the file attached to this email) and did not notice anything wrong and I didn’t notice any text/xml at the end of the input vector value.
> Can you please try with the same service and confirm that you don’t face the same issue ?
Yes, you are right.
The problem was in my json string. Thanks
> Best regards,
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss mailing list
