[Zoo-discuss] Zoo Java Service example / docs
Alexander Kmoch alexander.kmoch at aut.ac.nz
Thu Mar 12 16:37:34 PDT 2015
I am elaborating through the ZOO Java Services example. There are some
confusing hints in the docs [1]:
The Java code shows:
 > public class HelloJava
but speaks of a HelloWorld.class :-) That doesn't match. So I renamed
the the class to
 > public class HelloWorld
And also it is a bit complicated to figure the right HelloWorld.zcfg ->
In fact I realised the ZCFG file should be calles HelloWorldJava.zcfg
because it's the method within the HelloWorld.class that get's called by
ZOO if I understoo it correctly
###snippet start###
[HelloWorldJava]
Title = Java Demo Hello World
serviceType = Java
serviceProvider = HelloWorld
<MetaData>
   title = Metadata title of your service
</MetaData>
<DataInputs>
</DataInputs>
<DataOutputs>
</DataOutputs>
###snippet end###
I finally have to resolve a java.lang.UnsatisfiedLinkError: no ZOO in
java.library.path
This is the JAVA classpath thing I reckon, so I added some Env config to
the Apache2 for the CGI:
###snippet start###
SetEnv JAVA_HOME /usr/lib/jvm/java-7-openjdk-amd64
         SetEnv JAVA_OPTS "-Xmx512m
-Djava.library.path=/vol1/www/smart/includes/zoo-cgi-bin"
SetEnv CLASSPATH /vol1/www/smart/includes/zoo-cgi-bin
SetEnv LD_LIBRARY_PATH
/usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server:/vol1/www/smart/includes/zoo-cgi-bin
###snippet end###
And it runs now.
Cheers,
Alex
[1] http://zoo-project.org/docs/services/howtos.html#java
More information about the Zoo-discuss mailing list
