[Zoo-discuss] ZOOGrassModuleStarter instance has no attribute 'logfile
pablo zader pzader at gmail.com
Sat May 2 20:53:49 PDT 2015
Hi list
I'm working with GRASS GIS services, particularly "r.what".
Experiment a problem to define a nonexistent directory in GlobalGras
Settings.py file:
WORKDIR="/tmp/zoo"
OUTPUTDIR="/tmp/zoo"
LOGFILE="/tmp/zoo/logfile.txt"
LOGFILE_MODULE_STDOUT="/tmp/zoo/logfile_module_stdout.txt"
LOGFILE_MODULE_STDERR="/tmp/zoo/logfile_module_sterr.txt"
GRASS_GIS_BASE="/home/pablo/grass_trunk/dist.x86_64-unknown-linux-gnu"
GRASS_ADDON_PATH="/home/pablo/wps-grass-bridge/gms/Testing/Python/GrassAddons"
GRASS_VERSION="7.0.svn"
if the "/ tmp/zoo" directory does not exist, an error occurs:
<ExceptionReport xmlns="http://www.opengis.net/ows/1.1" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
xml:lang="en-US" version="1.1.0">
<Exception exceptionCode="NoApplicableCode">
<ExceptionText>
TRACE : ZOOGrassModuleStarter instance has no attribute 'logfile' <type
'exceptions.AttributeError'> Unable to run your python process properly.
Please check the following messages : [' File "/usr/lib/cgi-bin/r_what.py",
line 7, in r_what\n service.fromMaps("r.what", inputs, outputs)\n', ' File
"/usr/lib/cgi-bin/ZOOGrassModuleStarter.py", line 43, in fromMaps\n
self._createTemporalDir(GlobalGrassSettings.WORKDIR)\n', ' File
"/usr/lib/cgi-bin/gms/GrassModuleStarter.py", line 248, in
_createTemporalDir\n self.LogError(log)\n', ' File
"/usr/lib/cgi-bin/gms/ProcessLogging.py", line 70, in LogError\n
self.logfile.write("\\n<ERROR timestamp=\\"" + localtime + "\\">\\n")\n']
</ExceptionText>
</Exception>
</ExceptionReport>
There are two issues I want to raise:
   1. best would return an error message: "Can not create the directory",
   rather than "ZOOGrassModuleStarter instance has no attribute
   'logfile"??? (This is bug zoo-proyect??)
   2. If my tmp is:
   drwxrwxrwx  30 root root 12288 may  3 00:43 tmp
   Why zoo-project can not create the directory zoo?
Thanks in advanced
Pablo
*Pablo J. Zader*
*Lic. en Cs. de la Computación*
*pablo.zader at gmail.com <pablo.zader at gmail.com>*
*"Los Grandes Hombres hablan sobre ideas... Los Hombres Promedio hablan
sobre cosas... Los Hombres Pequeños hablan.. de otros Hombres.*
*del libro Matemática estas ahi? A. Paenza "*
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20150503/0377a91b/attachment.html>
More information about the Zoo-discuss mailing list
