[Zoo-discuss] Mapmint version fresh install error - cannot find -lzoo_service
karsten karsten at terragis.net
Mon Nov 2 17:12:16 PST 2015
Hi Gerald,
Thanks that worked to fix this issue.
Now I finished the fresh installation but am still heavily struggling with
the configuration to make this work.
I have pasted my config here http://pastebin.com/82yttHkV if it is of any
use.
My MM installation is here http://terra3.terragis.net/ui/Dashboard  and I
was trying to access it with the default user 'test' and passwd 'demo02'
That seems to get me in as the next page updates after clicking 'login' says
'user test authenticated' however the page then updates again
and gives and an error message: Requested page could not be loaded
unexpected EOF while parsing (, line 0)
Screen shot here www.terragis.net/docs/other/mmerror.png
When I check the data base log I see the error:
2015-11-02 19:10:37 EST STATEMENT:   SELECT users.*,(select name from
mm.groups where id=id_group) as gname FROM mm.users,mm.user_group,mm.groups
WHERE mm.users.id=id_user AND mm.groups.id=id_group AND adm=1 AND
login='test' AND passwd=[_password_]
To it seesm the EOF error is because the SQL above has an error ...
Now I am not sure at all why the password does not seem to have resolved in
the SQL that is run from [_password_]
to the real password ( md5 version of 'dem02'  ) ?
I also re-created the database mmdb and saw that all went troughtexcept
teher are two error reporetd when I run
psql mmdb -f mmdb.sql
psql:mmdb.sql:501: ERROR:  type "public.geometry" does not exist
LINE 6:     wkb_geometry public.geometry,
psql:mmdb.sql:504: ERROR:  relation "mm.savedpath" does not exist
Would you have any suggestions how the login problem above can be addressed
Thanks so much
Cheers
Karsten
-----Original Message-----
From: Fenoy Gerald [mailto:gerald.fenoy at geolabs.fr]
Sent: Wednesday, October 28, 2015 16:50
To: karsten at terragis.net
Cc: ZOO-discuss
Subject: Re: Mapmint version fresh install error - cannot find -lzoo_service
Hello Karsten,
you should run "make install && ldconfig" after building the ZOO-Kernel with
the make command.
It should solve this issue.
Hope this helps,
Best
> Le 28 oct. 2015 à 22:58, karsten <karsten at terragis.net> a écrit :
> Hi All,
> I am working on a fresh installation of MapMint on a fresh Ubuntu 14
server.
> In the installations sequence from
> https://github.com/mapmint/mapmint/blob/master/INSTALL.md in Install
> ZOO-Project and the C Services after changing to the ogr2ogr directory
> with cd $SRC/zoo/zoo-project/zoo-services/ogr/ogr2og
> Running the
> make
> command gives me the following error:
> terra at terra3:~/src/zoo/zoo-project/zoo-services/ogr/ogr2ogr$ make
> g++ -DZOO_SERVICE -I../../../../thirds/cgic206/ -I../../../zoo-kernel/
> -I/usr/include/libxml2 -I/usr/include/gdal -I/usr/include/python2.7
> -I/usr/include/x86_64-linux-gnu/python2.7 -DLINUX_FREE_ISSUE   -shared
-fpic
> service.c  -o cgi-env/ogr2ogr_service.zo -L/usr/lib -lgdal
> -lzoo_service
> /usr/bin/ld: cannot find -lzoo_service
> collect2: error: ld returned 1 exit status
> make: *** [cgi-env/ogr2ogr_service.zo] Error 1
> What is going wrong and how can I fix it ?
> Thanks and best regards
> Karsten
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
