[Zoo-discuss] Mapmint version fresh install error - cannot find -lzoo_service
Fenoy Gerald gerald.fenoy at geolabs.fr
Wed Nov 4 04:52:48 PST 2015
Hi Karsten,
thanks a lot for your feedbacks and congratulation for having setup MapMint on your platform.
I went on your server and I noticed that the issue with the new UI comes from this link which cannot be loaded : http://terra3.terragis.net/ui//admin;module=Distiller.js .
The /~djay/progede2/mapmint-ui/ is hardcoded in the mapmint-ui/.htaccess file, you will have to fix this values to get the new UI working.
For the missing images from the version 1 of the UI, it may require that you add an empty .htaccess in the mapmint-ui/img directory to solve the issue, indeed the setup try to use the tempting system to display images which is uncommon. I have personally a .htaccess in the img directory.
For the Dashboard I have the same behavior locally (about the values which are not filled in correctly in the form) so I suppose that this is a new bug coming with the modifications made in the service to retrieve the values. I will take a look at it lately but it should not hurt until you are not using this specific form by now.
For the Manager module you should know that it cannot be opened before you created a map, for instance by clicking on the "open in the manager » button from one datasource from the Distiller module. Since you did that the issue should be solved. Note that the LandCover001 reference comes from the database creation. I just took a quick look into mmdb.sql and it seemed to be created once a user used a LandCover001 project. You should simply forget this issue as it is not really an issue. We may remove this default value (which will be overwritten once you open a datasource in your Manager) to make sure no-one will try to open the Manager prior to create a project.
From what I can see it seems that your setup is in good shape, to get the new UI working you simply have to take a look into the .htaccess which was dedicated to my machine setup.
I may also switch back to a default setup, I have created a dedicated virtual machine in my infrastructure to test the setup, but then I switched back to my own personal machine to develop the new version which cause all the issue with path and Url setup and make it much more complicated. Note that any time this kind of issue occurs I am  able to solve them quickly but I now realize that using a basic setup (ubuntu or debian) may help for other to deploy the exact same setup.
Nevertheless, I suppose that this answers will help you and you can come back with the new UI version up and running soon.
I hope to hear back from you and thanks again for your interest in the MapMint Product,
Best regards,
ps: the new UI is far better, cause it work on your mobile phone or tablet even the administration interface, but it is even better for the Client interface which is perfectly working on your mobile phone. The administration interface have still some issue on mobile phone but work great on tablet, especially the Manager which may require to use the tablet in landscape mode to make sure to display everything properly, but still I think it is a real asset to be able to setup your map from your tablet this way you can setup your map from your bad or your bath :)
> Le 4 nov. 2015 à 04:55, karsten <karsten at terragis.net> a écrit :
> Hi Gerald and All,
> I installed PostGIS and pg_routing and created the respective extensions
> prior to running the SQL script for the database and that indeed fixed the
> two issues
> I reported below. I also created a dir in the default data Path
> (/var/data/georeferencer_maps).
> At one point druing my testing I had it so that the new "Bootstrap"
> Dashboard_bs displayed beautifully, but so far even at that point I could
> not log in that way yet.
> The other dashboard get me to log in ok but I still was trying all day to
> get the configuration of all the paths in main.cfg right
> but its has been a lot of educated guessing and trial and error and I am not
> there yet. I also downloaded the older MapMint iso from source forge and ran
> in on virtual box to be able to compare what worked in that setup ( main.cfg
> used in that iso) and what are my main.cfg ... However unbfortunatel the ISO
> image version seesm to have a different log in cernetials (test/demo02 are
> not working ) and I do not knw the corerct ones to fully test mapMint on
> there . Would you still know what that suer and pw is ?
> A couple of tings are quite curious / a bit strange still with my Dashboard-
> for example once I logged in the can see in firebug a call to zooloader.cgi
> http://terra3.terragis.net/cgi-bin/mm/zoo_loader.cgi?service=WPS&version=1.0
> .0&request=Execute&Identifier=configuration.GetConf&DataInputs=section=main&
> RawDataOutput=Result&_=1446603788818
> And the results are all returned however in the interface those values are
> not filled into the Tab on the left except for the entries for the values of
> "Supporteddbs" [PostGIS,MySQL,WFS] and "3D" [false] - is that supposed to be
> like that ? To me this seems that something is not set right for this yet.
> The next noticeable problem is that then image icons are not appearing in
> the display see thess screen shots ,
> www.terragis.net/docs/other/mm_distiller.png
> www.terragis.net/docs/other/mm_manager.png
> www.terragis.net/docs/other/mm_dashboard.png
> Thus is seems that a path is not yet right (but which one I need to fix and
> how I am at a complete loss so far)
> Overall the links to Distiller, Manager, Themes; Documents and Publisher are
> all working but those tabs seems nonetheless not correctly working yet (see
> above how they display). In Firebug I can not see any error (except for
> manager details below)  also all file paths seem to be found (no red files
> in firebug in NET tab).The Call below for opening Manager gives an error in
> Firebug: SyntaxError: expected expression, got '<'
> http://terra3.terragis.net/cgi-bin/mm/zoo_loader.cgi?request=Execute&service
> =WPS&version=1.0.0&Identifier=template.display&DataInputs=tmpl=manager_tree_
> js;module=Manager&RawDataOutput=Result at mimeType=text/plain
> here I have seen that the problem is that project_LandCover001.map is not
> included in the install and thus not in /var/data/maps/
> but in the user interface. I should probably just add my own map instead
> here I guess.
> Would you have any suggestions how the configuration problem above can be
> addressed ?
> Thanks so much
> Cheers
> Karsten
> PS: For reference I included my main.cfg
> [main] section below.
> [main]
> encoding=utf-8
> mmAddress=/ui/
> dataPath=/var/data
> tmpPath=/var/www/html/tmp
> supportedDbs=PostGIS,MySQL,WFS
> cacheDir=/var/www/cache
> isSoap=false
> 3D=false
> rootUrl=http://terra3.terragis.net/ui/public/
> publicationUrl=/pm
> dblink=/var/data/mm.db
> mmPath=/home/terra/src/mapmint/mapmint-ui
> version=1.0.0
> Rpy2=true
> dbuser=npdb
> sessPath=/tmp
> applicationAddress=http://terra3.terragis.net/ui
> dbuserName=mmdb
> isTrial=true
> publicationPath=/var/www/html/pm
> cssCache=prod
> msOgcVersion=1.0.0
> serverAddress=http://localhost/cgi-bin/zoo_loader.cgi
> lang=en-US,ja-JP,fr-FR
> crs=IGNF:LAMB93
> cookiePrefix=MMID
> templatesAddress=http://terra3.terragis.net/tmpl/
> language=en-US
> rversion=1.0.0
> mapserverAddress=http://localhost/cgi-bin/mapserv
> tmpUrl=http://terra3.terragis.net/tmp/
> templatesPath=/home/terra/src/mapmint/mapmint-ui/templates/
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
