[Zoo-discuss] ZOO and Mapserver 6.4
Venkatesh Raghavan raghavan at media.osaka-cu.ac.jp
Thu Nov 5 06:11:25 PST 2015
On 2015/11/05 22:00, Fenoy Gerald wrote:
> Thanks a lot for this effort which will help confirming that everything is fine with MapServer 7.0.0 support in ZOO-Project.
Great news. I down and 7 to go (Gerald will understand)
Best
Venka
> Best regards,
>> Le 5 nov. 2015 à 13:53, Jeff McKenna <jmckenna at gatewaygeomatics.com> a écrit :
>> I will try to compile this on Windows and report back here.
>> -jeff
>> On 2015-11-05 8:30 AM, Jeff McKenna wrote:
>>> Hi Gérald, I am curious if you were able to get this MapServer 7 patch
>>> working with Windows.  Please let me know.
>>> -jeff
>>> On 2015-11-05 6:22 AM, Fenoy Gerald wrote:
>>>> Dear Luca,
>>>> as promised I take a quick look for trying to build the ZOO-Kernel
>>>> against the MapServer 7.0.0 version.
>>>> Strangely it worked with only few modifications in the source code, in
>>>> fact commenting 2 lines was enough to get it working. I probably tried
>>>> before the official release of the 7.0.0 version cause it seems to
>>>> work perfectly from what I can see. I’ve re-used the workshop material
>>>> in the VM and put in place the MapServer 7.0.0 version, then rebuild
>>>> the ZOO-Kernel and strongly it worked. Obviously I had to modify the
>>>> ZOOMakefile.opts to fit with my MapServer setup (mainly to make it
>>>> able to find the mapserver-config.h which was unfortunately not
>>>> installed by make install from the MapSever directory).
>>>> I’ve made all the modifications required available in the patch
>>>> attached to this mail to avoid having to edit any files during the
>>>> building procedure.
>>>> So I would like you to try the following, starting a fresh svn checkout :
>>>> patch -p0 < ms7.patch
>>>> autoconf
>>>> ./configure —with-python —with-js
>>>> —with-mapserver=<FULL_PATH_TO_MS_SOURCE_CODE>
>>>> make
>>>> sudo make install && sudo ldconfig
>>>> This suppose that you run make not directly in the MapServer source
>>>> code directory but in a build subdirectory. In other case you will
>>>> need to edit the configure.ac file to point to your build location (it
>>>> is required to find the mapserver-config.h file).
>>>> I have made only tests using the routing service from the ZOO-Project
>>>> workshop so there may be some issue for some specific services but I
>>>> don’t why we may have any issue in publishing something else than
>>>> lines (the result of the routing service is a set of lines).
>>>> I hope you can confirm that the MapServer 7.0.0 support is working, if
>>>> it is also working on your side, then I will apply a more general
>>>> patch to the SVN and commit it. I think that we should keep the source
>>>> code as it was for the 6.2.0 version which is working like a charm for
>>>> some years now and adapt for the 7.0.0 version by using ifdef block
>>>> around the two lines I’ve juste commented in the patch I provided.
>>>> I hope to hear back from you,
>>>> Best regards,
>>>>> Le 5 nov. 2015 à 10:26, Fenoy Gerald <gerald.fenoy at geolabs.fr> a écrit :
>>>>> Dear Luca,
>>>>> thanks a lot for coming back on this topic.
>>>>> I’ve discussed the issue I faced when passing to 7.0 with Thomas
>>>>> during the foss4g in Seoul and he told me that now we have to
>>>>> initialize the map object with some initializing functions dedicated
>>>>> to allocate memory. Indeed from what I was able to try some months
>>>>> back the ZOO-Kernel failed due to segmentation violation which should
>>>>> be caused by a memory part which was not correctly initialized.
>>>>> I will try to upgrade to MapServer 7.0 on a VM and will let you know
>>>>> what are the result.
>>>>> Best regards,
>>>>>> Le 5 nov. 2015 à 09:33, Luca Delucchi <lucadeluge at gmail.com> a écrit :
>>>>>> On 28 January 2014 at 11:12, Fenoy Gerald <gerald.fenoy at geolabs.fr>
>>>>>> wrote:
>>>>>>> Dear Luca,
>>>>>> Dear Gerald,
>>>>>> I'm back on this topic
>>>>>>> you should try using the following:
>>>>>>>> MS_LDFLAGS=/home/lucadelu/compilati/mapserver-6-4-1/build/libmapserver.so
>>>>>>> You kept the « -L » in what you gave initially.
>>>>>>> For the CFLAGS, I’m not sure this is correct as you said that you
>>>>>>> built Mapserver in some other place, so the
>>>>>>> "-I/home/lucadelu/compilati/mapserver-6-4-1/"  should point to the
>>>>>>> location where MapServer was built.
>>>>>>>> MS_CFLAGS=-DUSE_MS   -I/home/lucadelu/compilati/mapserver-6-4-1/
>>>>>> any news to compile zoo against mapserver 6.4.1? or in the worst case
>>>>>> did you try with mapserver 7?
>>>>>>> Hope this helps,
>>>>>>> Best regards,
>>>>>> ciao
>>>>>> Luca
>>>>>> http://gis.cri.fmach.it/delucchi/
>>>>>> www.lucadelu.org
>>>>>> _______________________________________________
>>>>>> Zoo-discuss mailing list
>>>>>> Zoo-discuss at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
>>>>> Gérald Fenoy
>>>>> http://wiki.osgeo.org/wiki/User:Djay
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
> Gérald Fenoy
More information about the Zoo-discuss mailing list
