[Zoo-discuss] ZOO and Mapserver 6.4
Fenoy Gerald gerald.fenoy at geolabs.fr
Fri Nov 6 01:24:55 PST 2015
Luca,
I suppose that your GDAL headers are located in the following directory : /usr/include/gdal ?
If yes, this is the issue. So you should manually edit your Makefile to add -I/usr/include/gdal to the CFLAGS and everything should build correctly then.
I hope to hear back from you,
Best regards,
> Le 5 nov. 2015 à 15:43, Luca Delucchi <lucadeluge at gmail.com> a écrit :
> On 5 November 2015 at 15:37, Fenoy Gerald <gerald.fenoy at geolabs.fr> wrote:
>> Dear Luca,
>> thanks a lot for your feedbacks, you should replace -I$MS_SRC_PATH /build by -I$MS_SRC_PATH/build in the MS_CFLAGS.
>> This issue comes from the patch, fix it directly in your local ZOOMakefile.opts.
> fixed now, another problem
> http://pastebin.com/wGsSXUsB
> cpl_conv.h is in libgdal-dev and I have it installed
>> Hope to hear back from you,
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
