[Zoo-discuss] Java services sharing the same class
Francesco Barchetta francesco.barchetta at terradue.com
Fri Jan 8 09:43:09 PST 2016
Dear all,
In order to have the possibility to add dynamically a new Java service to the WPS server, it would be useful for me to exploit the same java class (AND methods) from different .zcfg files .
I understand that this is not possible at the moment due to some name limitations (from the doc):
> For each Service provided by your ZOO Java Services Provider (your corresponding Java class), the ZCFG File should have the name of the Java public method corresponding to the service (case-sensitive).
Anyway I see three simple changes to the kernel to enable this behavior :
1) Adding the possibility to specify the WPS Identifier in the .zcfg file (not related to any methods).
2) Adding the possibility to specify the main method identifier in the .zcfg file .
3) Adding the possibility to specify the serviceProvider at the generic or profile level .
What do you think? Any chances to see one of these implemented one day?
Thanks in advance.
Best regards,
Francesco.
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160108/424bae0a/attachment.bin>
More information about the Zoo-discuss mailing list
