[Zoo-discuss] Zoo kernel not loading Python services
Balajee R.C balajee at vizexperts.com
Tue Jul 12 03:25:27 PDT 2016
Fenoy Gerald,
Bingo. That was indeed the problem. Removed the py extension and it started
working.
I feel silly for not having tried that myself.
Anyway, problem solved. Thanks a ton.
Regards,
Balajee.R.C
On Tue, Jul 12, 2016 at 3:37 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>
wrote:
> Hello,
> I suppose that you have set the value « test.py » in your zcfg file for
> the serviceProvider. Nevertheless, it is not require to write the extension
> .py to the python module to be loaded. So you should use test rather than
> test.py to solve your issue.
> In case you have a subdirectory named test, then you may try adding a
> __init__.py file to make the ZOO-Kernel able to find the py module located
> in the test subdirectory.
> I hope it helps and yo can confirm that your issue is solved.
> Best regards,
> > Le 11 juil. 2016 à 08:31, Balajee R.C <balajee at vizexperts.com> a écrit :
> > I have built zoo from svn (rev. 784) with --with-python enabled. I am
> using Python version: 2.7.5
> > I have the following Python based service:
> > import zoo
> > def test(conf, inputs, outputs):
> >    outputs["output"]["value"] = "Hello from Python World !"
> >    return 3
> > When I execute the above service, I get the following error:
> > <?xml version="1.0" encoding="utf-8"?>
> > <ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd"
> xml:lang="en-US" version="1.1.0">
> >     <ows:Exception exceptionCode="NoApplicableCode">
> >         <ows:ExceptionText>Python module test.py cannot be loaded.
> Message: TRACE: No module named py
> > <type 'exceptions.ImportError'>
> > </ows:ExceptionText>
> >     </ows:Exception>
> > </ows:ExceptionReport>
> >  However, I do notice that they pyc file for my service test.py file HAS
> indeed been created. Hence, it appears that the trouble is that there is
> another module named py that it is trying to load.
> > I have already done pip install py for my python installation. When I
> launch my python interpreter directly and do:
> > import py
> > then this works without an error.
> > What could be going wrong? Can someone please point me in the right
> direction?
> > Regards,
> > Balajee.R.C
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160712/89401255/attachment.html>
More information about the Zoo-discuss mailing list
