[Zoo-discuss] Using gdal_warp service fails sometimes
Fenoy Gerald gerald.fenoy at geolabs.fr
Fri May 6 03:21:43 PDT 2016
Hi Thomas,
sorry for late reply.
Thanks a lot for you report. May I ask you to send the request you have used to face the issue ?
You are right mentioning that the issue seems to come from the ZOO-Kernel when it output the XML result.
I would like to know if the issue only occurs by changing the input data or depend on the output format specified ?
I hope to hear back from you for being able to solve the issue.
Best regards,
> Le 4 mai 2016 à 18:28, Thomas Tilak <thomas.tilak at gmail.com> a écrit :
> I am using trunk version of zoo-project retrieved from a checkout on http://svn.zoo-project.org/svn/trunk.
> The gdal_warp service fails on some input data while it is perfectly working on other. I do not suspect gdal process because output data is created correctly but the service freezes and does not finish.
> I activated debug options both in kernel and service compile and it seems to fail when writing xml response.
> I used gdb to try to figure out what was going on and here is the result of bt:
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff51d7e2d in ?? () from /lib/x86_64-linux-gnu/libc.so.6
> (gdb) bt
> #0  0x00007ffff51d7e2d in ?? () from /lib/x86_64-linux-gnu/libc.so.6
> #1  0x00007ffff51da314 in ?? () from /lib/x86_64-linux-gnu/libc.so.6
> #2  0x00007ffff51dca40 in malloc () from /lib/x86_64-linux-gnu/libc.so.6
> #3  0x00007ffff6151e2e in xmlBufferCreate () from /usr/lib/x86_64-linux-gnu/libxml2.so.2
> #4  0x00007ffff615b20f in xmlAllocOutputBuffer () from /usr/lib/x86_64-linux-gnu/libxml2.so.2
> #5  0x00007ffff620722e in xmlDocDumpFormatMemoryEnc () from /usr/lib/x86_64-linux-gnu/libxml2.so.2
> #6  0x000000000041191b in printDocument ()
> #7  0x000000000041186d in printProcessResponse ()
> #8  0x0000000000414100 in outputResponse ()
> #9  0x0000000000408f23 in runRequest (inputs=<optimized out>) at zoo_service_loader.c:2176
> #10 0x0000000000405d75 in cgiMain () at zoo_loader.c:402
> #11 0x0000000000427b13 in main (argc=2, argv=0x7fffffffebd8) at cgic.c:312
> I can provide all the output provided by debug option at execution if needed.
> I hope you will be able to find what is going on here.
> Regards.
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
