[Zoo-discuss] Handling output files
pablo zader pzader at gmail.com
Tue May 10 13:09:40 PDT 2016
Hi
Sorry the intrusion.
I think taking the reference data but through WCS and WFS, the
responsibility of the goodness of data is the map server. That is,
zoo-kernel is released from the validation.
Best regards
Pablo
El 6/5/2016 8:04 a. m., "rakesh prithiviraj" <rakeshuk at outlook.com>
escribió:
> Ok thanks. Just to summarize:
> Either the output file content is assigned to "value" field or the output
> file name is assigned to "generated_file" field (assuming the output file
> is available under tmpPath)
> Scenario 1: User has set"asReference" to true
> ZOO-kernel will generate the reference URL
> Scenario 2: User has set "asReference" to false
> ZOO-kernel will embed the output in the response.
> Regards
> Rakesh
> > Subject: Re: [Zoo-discuss] Handling output files
> > From: gerald.fenoy at geolabs.fr
> > Date: Fri, 6 May 2016 12:17:33 +0200
> > CC: zoo-discuss at lists.osgeo.org
> > To: rakeshuk at outlook.com
> > Hi Rakesh,
> > My answer inline bellow.
> > > Le 4 mai 2016 à 00:22, rakesh prithiviraj <rakeshuk at outlook.com> a
> écrit :
> > > Hi,
> > > I have a legacy Java code that processes several input files (images,
> text files together) and generates multiple output files in different
> formats. The output files are stored in a particular directory
> (configuration parameter of the processor). I am planning to create a
> wrapper processor for this legacy code so that I can use it based on WPS
> standards.
> > > The wrapper WPS processor will receive 3 parameters (conf, inputs,
> outputs) and I will pass the inputs to the legacy code which will process
> the input and will create output files. I will have a list of Java File
> objects as a result. To handle this scenario, in the zcfg file, I can write
> something as follows for each of the output. But this is clearly not
> sufficient to make the output files URLs appear in GetResult response.
> > > <DataOutputs>
> > > [Result1]
> > > Title = This is result 1
> > > Abstract = A image file .
> > > <ComplexData>
> > > <Default>
> > > mimeType = image/tiff
> > > extension = tif
> > > </Default>
> > > </ComplexData>
> > > </DataOutputs>
> > > In the WPS wrapper code, how do I push the output files to the
> "outputs" parameter (passed to wrapper processor). In the hello-java
> example, string is pushed to the "outputs" as follows:
> > > HashMap hm1 = (HashMap)(outputs.get("Result"));
> > > hm1.put("value",ZOO._("Hello "+v+" from JAVA World !!"));
> > In case you are already writing the file to the file system, then you
> can decide to write the same data in the value field of your output.
> Nevertheless, there is a trick here that can be of some use for your
> specific case. When we have integrated the SAGA-GIS services, we faced the
> exact same issue. Meaning that we are dealing with file generated on the
> file system. So, we added handling of a specific field named «
> generated_file » which let you directly give the name of the generated
> file. The limitation to this method is that your file have to be stored in
> the path defined in the tmpPath parameter of the [main] section of the
> main.cfg file of your setup.
> > > Similarly if I push file java object to the "value" key, will the
> GetResult response contain URL of the output file on the server?
> > Whatever method you choose (generated_file or writing data to the value
> field) the ZOO-Kernel will generate the reference URL only in case the user
> have requested for it (meaning that he have set the asReference attribute
> to true). It means also that even if you used the generated_file field and
> the user sent a request specifying that he want the output data embedded in
> the XML response, then it should work in a totally transparent way.
> > > Also who is responsible for making the output files (generated in some
> directory) on the server as a web accessible resource (via URL)?
> > As I tried to explain earlier, in case you have the value field defined
> and containing the data, then the ZOO-Kernel is responsible to generate a
> file on the file system (in the tmpPath directory) and generate the
> reference URL depending on the request. In case you use generated_file,
> then the ZOO-Kernel will be responsible to read the file content in case
> the request specify that the output should not be returned as a reference.
> > Hope it helps.
> > Best regards,
> > Gérald Fenoy
> > http://wiki.osgeo.org/wiki/User:Djay
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160510/4e240a82/attachment.html>
More information about the Zoo-discuss mailing list
