[Zoo-discuss] GSoC Report 1
Niroshan Sanjaya
nsanj88 at gmail.com
Sun May 29 02:51:40 PDT 2016
Hi All,
GSoC coding period has been started on 23 May 2016. Here is the work which
I have done in the 1st
week of coding. In this email contains the report which I have submitted to
the OSGeo-SoC.
What did you get done this week?
After familiar with the ZOO-Project in the Community Bonding Period, I have
started to implementing different services by using python.
I worked on implementing a service based on Java script and I created a
working example. After that I started to implementing JGrass tools as a
service, Still I am working on that.
What do you plan on doing next week?
In next week I am planning to finish the implementation of JGrass tools as
a web service. After that I will start to test its functions as a web
service.
Are you blocked on anything?
Recently, I shifted from linux environment to windows environment.
I have face several difficulties when I am setting up the environments, but
it has been solved thanks to my mentor Gerald Fenoy.
I am not blocked at the movement actually, but my work is quite slow since
I do not have much experience in using Java scripts.
your comments and suggestions are welcome.
Best
Niroshan Sanjaya
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160529/fb1fe581/attachment.html>
More information about the Zoo-discuss
