[Zoo-discuss] Service provider packaged as jar
rakesh prithiviraj rakeshuk at outlook.com
Tue May 31 05:56:08 PDT 2016
Thanks Gerald. It worked. I could use jar files directly now without needing to unpack them.
> Subject: Re: [Zoo-discuss] Service provider packaged as jar
> From: gerald.fenoy at geolabs.fr
> Date: Tue, 31 May 2016 12:33:29 +0200
> CC: zoo-discuss at lists.osgeo.org
> To: rakeshuk at outlook.com
> Dear Rakesh,
> sorry for late reply.
> You can probably define the jar files your service is depending on, in the CLASSPATH environment variable. This can be done by adding a CLASSPATH key in the [env] section in your main.cfg file. So something like the following should solve your issue:
> [env]
> CLASSPATH=/the/path/of/you/file.jar:/any/other/depenpendencies.jar
> I hope to hear back from you.
> Best regards,
> > Le 30 mai 2016 à 16:28, rakesh prithiviraj <rakeshuk at outlook.com> a écrit :
> > Hi,
> > I have a java wps processor (zoo service) that is package as jar file. I used "maven-assembly-plugin" to build a jar file with all its dependencies and I placed the jar file under "/usr/lib/cgi-bin".
> > In the myService.zcfg config file, the service provider (Java Class) is given as follows
> >  serviceProvider = com/eoss/core/wpswrapper/WPSWrapperProcessor
> > When I execute my service, I get "Class Not Found" exception though the jar file is available under "/usr/lib/cgi-bin" where Zoo kernel is also present.
> > Note in "main.cfg", LD_LIBRARY_PATH points to "/usr/lib/cgi-bin"
> > LD_LIBRARY_PATH=/usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/:/usr/lib/cgi-bin
> > But if I unpack the jar file (which results in several folders being created under /usr/lib/cgi-bin for all the dependencies) then my service is executing as expected.
> > Is it possible to use "jar" file instead of unpacking it to execute the service?
> > Thanks for your help.
> > regards
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160531/708ae602/attachment-0001.html>
More information about the Zoo-discuss mailing list
