[Zoo-discuss] Are WPS 2.0.0 Execute ComplexData Inputs passed to Python services correctly?
Lech Karłowicz lendrom at gmail.com
Tue Jan 17 08:21:25 PST 2017
It would be most helpful if it was possible for you to provide the version
(and instructions) with which I could update my current setup. But I'm
sorry if I wasn't specific enough about the version of OSGeo I use. I don't
use bootable DVD version, I use OsGeo-live-10.0-vm (vmdk) deployed on
Virtual Box (downloaded from
https://sourceforge.net/projects/osgeo-live/files/10.0/osgeo-live-10.0-vm.7z/download).
I'm not really sure where to find a more specific version number. Is this
setup suitable for your 'patch'?
Best regards
Lech
2017-01-17 14:33 GMT+01:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> Hello,
> thanks for your return.
> In case it may be of any help for you, I should be able to provide the
> OSGeoLiveDVD binary version. I only need the exact version number of you
> osgeolivedvd. This way you will only need to unpack the archive with a tat
> command that I will give to you in case you are interested in getting this
> binary version. In fact, I will have to build the ZOO-Kernel on
> OSGeoLiveDVD solve the issue reported on another thread about OTB 5.8.0
> which seems to fail at compilation time. So please do not consider that it
> will much work to me, nevertheless, there is no direct interest for
> publishing the binary versions except if somebody is interested in.
> I hope to have an answer from you.
> Best regards,
> > Le 17 janv. 2017 à 09:11, Lech Karłowicz <lendrom at gmail.com> a écrit :
> > Thank you for taking your time to clarify that. I'll try to test it
> after building the lastest svn version but I'm not really experienced with
> building software from sources (that's why I love osgeo-live for tests) so
> it may take a while (with possibility of failing miserably).
> > Best Regads,
> > Lech
> > 2017-01-16 23:20 GMT+01:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> > Hello,
> > thanks for your feedback.
> > You are right only CDATA is supported. Can you please give the latest
> SVN version a try and confirm that your issue is solved with this version ?
> > Best regards,
> > > Le 16 janv. 2017 à 13:05, Lech Karłowicz <lendrom at gmail.com> a écrit :
> > > I modified the code of ogr_sp.py to log values of parameters that are
> passed by ZOO to the UnionPy function and I can see, that
> inputs['InputEntity1']['value'] is equal to '\n' or '\n\t\t' so it looks
> like ZOO does not pass inputs correctly. Or I am doing something wrong. I'd
> be very grateful for clarifying that.
> > Gérald Fenoy
> > http://wiki.osgeo.org/wiki/User:Djay
> Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20170117/aa3b6c9f/attachment.html>
More information about the Zoo-discuss mailing list
