[Zoo-discuss] Are WPS 2.0.0 Execute ComplexData Inputs passed to Python services correctly?
Lech Karłowicz lendrom at gmail.com
Tue Jan 17 14:09:32 PST 2017
after some tries I managed to compile ZOO following the instructions you
pointed me to. Indeed, I had to install some '-dev' packages to be able to
compile. But after executing the command "sudo make install" GetCapabilities
(or any other request to http://127.0.0.1/cgi-bin/zoo_loader.cgi) gives
returns internal server error (code 500).
I checked Apache logs and I can see the following errors (they appear after
every request to zoo_loader.cgi):
[Tue Jan 17 22:52:22.000113 2017] [cgi:error] [pid 6103] [client
127.0.0.1:56476] AH01215: /usr/lib/cgi-bin/zoo_loader.cgi: symbol lookup
error: /usr/lib/cgi-bin/zoo_loader.cgi: undefined symbol: createMaps:
[Tue Jan 17 22:52:22.001663 2017] [cgi:error] [pid 6103] [client
127.0.0.1:56476] End of script output before headers: zoo_loader.cgi
It looks like I'm missing some dependency, but I'm not sure which.
Best regards,
Lech
2017-01-17 18:57 GMT+01:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> Hello,
> OSGeoLiveDVD 10.0 should be perfect to build the ZOO-Kernel.
> Nevertheless, it may imply installing many things (-dev package) for being
> able to build it, see here for more informations about this [1], I guess
> the ubuntu instructions should work.
> Best regards,
> [1] http://www.zoo-project.org/docs/install/debian.html
> > Le 17 janv. 2017 à 17:21, Lech Karłowicz <lendrom at gmail.com> a écrit :
> > It would be most helpful if it was possible for you to provide the
> version (and instructions) with which I could update my current setup. But
> I'm sorry if I wasn't specific enough about the version of OSGeo I use. I
> don't use bootable DVD version, I use OsGeo-live-10.0-vm (vmdk) deployed on
> Virtual Box (downloaded from https://sourceforge.net/
> projects/osgeo-live/files/10.0/osgeo-live-10.0-vm.7z/download). I'm not
> really sure where to find a more specific version number. Is this setup
> suitable for your 'patch'?
> > Best regards
> > Lech
> > 2017-01-17 14:33 GMT+01:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> > Hello,
> > thanks for your return.
> > In case it may be of any help for you, I should be able to provide the
> OSGeoLiveDVD binary version. I only need the exact version number of you
> osgeolivedvd. This way you will only need to unpack the archive with a tat
> command that I will give to you in case you are interested in getting this
> binary version. In fact, I will have to build the ZOO-Kernel on
> OSGeoLiveDVD solve the issue reported on another thread about OTB 5.8.0
> which seems to fail at compilation time. So please do not consider that it
> will much work to me, nevertheless, there is no direct interest for
> publishing the binary versions except if somebody is interested in.
> > I hope to have an answer from you.
> > Best regards,
> > > Le 17 janv. 2017 à 09:11, Lech Karłowicz <lendrom at gmail.com> a écrit :
> > > Thank you for taking your time to clarify that. I'll try to test it
> after building the lastest svn version but I'm not really experienced with
> building software from sources (that's why I love osgeo-live for tests) so
> it may take a while (with possibility of failing miserably).
> > > Best Regads,
> > > Lech
> > > 2017-01-16 23:20 GMT+01:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> > > Hello,
> > > thanks for your feedback.
> > > You are right only CDATA is supported. Can you please give the latest
> SVN version a try and confirm that your issue is solved with this version ?
> > > Best regards,
> > > > Le 16 janv. 2017 à 13:05, Lech Karłowicz <lendrom at gmail.com> a
> écrit :
> > > > I modified the code of ogr_sp.py to log values of parameters that
> are passed by ZOO to the UnionPy function and I can see, that
> inputs['InputEntity1']['value'] is equal to '\n' or '\n\t\t' so it looks
> like ZOO does not pass inputs correctly. Or I am doing something wrong. I'd
> be very grateful for clarifying that.
> > > Gérald Fenoy
> > > http://wiki.osgeo.org/wiki/User:Djay
> > Gérald Fenoy
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20170117/b2d386e4/attachment.html>
More information about the Zoo-discuss mailing list
