[Zoo-discuss] ZOO-Project 1.6.0 Release
Fenoy Gerald gerald.fenoy at geolabs.fr
Sun Jan 29 06:46:58 PST 2017
Dear all,
we are glad to announce the publication of the ZOO-Project 1.6.0 release that can be downloaded from here : [1].
The new release includes enhancements, changes and bug fixes, the most important ones are listed bellow :
  * Install symbols.sym and updateStatus.xsl in dataPath
  * Generate main.cfg setting dataPath to SHAREDSTATEDIR
  * Fix to fetch default iotype when no value is provided
  * Fixes for building with OTB 5.8 support and ITK 4.10
  * Fix issue with nested xml Data
  * Add the C# as a supported programming language for Services
  * Add nested inputs and outputs support (WPS 2.0.0)
  * Add servicePath special key to specify the service location
  * Add the PHP version 7 support
  * Add --with-etc-dir option to specify the location of the main.cfg file
  * Support GDAL version 2.1.0.
  * Add the !MapServer 7.0.1 internal support.
  * Support for exotic location of openssl.
  * Add ZOO-Client API documentation reference in the official documentation.
  * Add CORS support.
  * Fix issue when dealing with Array in !JavaScript support.
  * Update the Centos installation procedure.
  * Small fixes in java support.
  * Fix issue when XML request contains empty nodes for inputs
  * Add status update for contour lines computation
  * Fix FASTCGI location using the --with-fastcgi option.
  * Redefined the API function addToMapWithSize to fix problem with Python/PHP support.
We hope you will have great time using this new release and we look forward for your feedbacks!
We would also like to thanks Venka and Niroshan for organizing the ZOO-Project workshop during this week Hyderabad! [2]
Best regards,
[1] http://zoo-project.org/Code/Download
[2] http://www.foss4g-asia.org/2017/programmenu/workshops/
GĂ©rald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-discuss mailing list
