[Zoo-discuss] Information required about Ubuntu Bionic zoo packages
Gérald Fenoy gerald.fenoy at geolabs.fr
Wed Sep 12 06:28:10 PDT 2018
Hi Angelos,
there is no mention of the Python 3 support in the HISTORY.txt file. Nevertheless, it is supported.
For linking specifically against another version than the the default one (usually version 3), you should use the « —with-pyvers=2.7 » configure option. In case you do not specify any specific Python version with this option then, your ZOO-Kernel should be linked against Python 3 and support Python 3 services.
Best regards,
Gérald Fenoy
http://wiki.osgeo.org/wiki/User:Djay
> Le 12 sept. 2018 à 12:00, Angelos Tzotsos <gcpp.kalxas at gmail.com> a écrit :
> Hi Suzana,
> Thanks for the feedback.
> In the OSGeoLive setup, here is the list of packages installed to make the services available to the demo application:
> https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_zoo-project.sh#L51
> In order to compile new services you need to install libzoo-service-dev package.
> About your Python question, the packages were built with Python2 support. I am not sure if Python3 is supported in 1.6.0 release.
> Gerald, can you please provide an insight on this one?
> Best,
> Angelos
> On Wed, Sep 12, 2018 at 11:06 AM Suzana Barreto <suzana.barreto at envsys.co.uk> wrote:
> Hi all,
> I have installed the zoo-kernel package for Ubuntu Bionic from the OSGeoLive repository  at https://launchpad.net/~osgeolive/+archive/ubuntu/nightly/+packages?field.name_filter=&field.status_filter=published&field.series_filter=bionic and have managed to get it up and running but I do not have any services listed when I do a GetCapabilities request. I realise that I need to compile the services and copy over their config files to the cgi-bin folder but the compilation on some services are failing.   On the OSGeoLive repo page, I notice that there are zoo-project packages, zoo-services packages and libzoo-service packages.  If I want to be able to take advantage of the OTB and other services, is it best to install each package individually, or does the zoo-project package provide everything required?
> I would also like to develop my own python services - do I need to install the libzoo-service and libzoo-service-dev packages to do that.
> Also, I see that the python that the zoo-kernel was compiled with is 2.7, does that mean that I cannot create python services with python 3?
> Any help much appreciated.
> Thanks,
> Suzana
> Dr Suzana Barreto
> Software Analyst
> Environment Systems
> Tel: +44 (0) 1970 626688
> www.envsys.co.uk
> The information contained in this e-mail is intended only for the use of the person(s) to whom it is addressed and may contain confidential or privileged information. If you have received this e-mail in error please contact the sender and delete the material without copying, distributing or disclosing the content. All reasonable precautions have been taken to ensure that this e-mail is free from any virus, however, the recipient should verify this to be the case. Please 'think before you print'
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
> Angelos Tzotsos, PhD
> OSGeo Charter Member
> http://users.ntua.gr/tzotsos
More information about the Zoo-discuss mailing list
