[Zoo-discuss] compile zoo kernel with python 3.7
Kobe De Decker kobededecker at gmail.com
Wed Feb 5 03:37:14 PST 2020
Hi Gerald,
thank you for you reply.
I just tried this but it doesn't make a difference.
Don't know if i can add screen captures here but i'll try:
[image: image.png]
I think the pyvers is rather used for finding libpython, and this one has
the minor version attached to it. So entering 3 or 3.7 results in the same
error. Python-config is found correctly.
Where could i check if the PyObject_CallObject element is included in the
python distribution?
thanks,
Kobe
Op wo 5 feb. 2020 om 10:39 schreef Gérald Fenoy <gerald.fenoy at geolabs.fr>:
> Hi Kobe,
> sorry for late reply.
> The Python 3 should be correctly supported, at least it is the version
> that is currently used within MapMint thanks to the work started during
> last year GSoC by Fenil Mehta (ref. https://github.com/fenilgmehta/mapmint
> Thanks for your feedback about the comment line (617 of configure.ac)
> which is wrongly referring to libphp when lib python is verified, this will
> be fixed. For the version number, it is mainly used to find the right
> python-config that may be named python3-config on some platform (usually
> where there are both python 2 and 3 available), hence you can specify the
> specific version number you want to use.
> Nevertheless, from what you have provided I can notice that you mentioned
> the major, minor version number when only the major version is expected.
> Supposing that there is a « python-config » program named python3-config
> from your build system, then it should be ok and the python library should
> be properly found.
> Hence, I suppose that in case you run you configure command by replacing
> the —with-pyvers=3.7 by —with-python=3 it should work.
> I hope it helps.
> Best regards,
> Gérald Fenoy
> ZOO-Project PSC Chair
> Le 4 févr. 2020 à 11:33, Kobe De Decker <kobededecker at gmail.com> a écrit :
> Hi there,
> I was using Zoo WPS successfully for many projects using it in a Docker
> image i built myself. Lately Python 2.7 has been deprecated, and I can't
> deploy new zoo services anymore as many of my processes use numpy and I get
> installation errors saying that numpy cant be installed anymore on this old
> Python.
> I have been trying to compile the Kernel with Python 3.x (in Conda) for a
> couple of days now, but am stuck on the last phase of the configure step.
> This is wat I enter:
> ./configure --with-python=/opt/app-root/src/miniconda3 --with-pyvers=3.7
> --prefix=/usr --libdir=/usr/lib64
> But the process breaks on this line:
> checking Python.h usability... yes
> checking Python.h presence... yes
> checking for Python.h... yes
> checking for PyObject_CallObject in -lpython3.7... no
> configure: error: could not find libpython
> So the configure phase definitely finds my python installation, but fails
> its last check. If i check in configure and configure.ac files, this
> should have something to do with linking with libphp (while I dont need php
> for my processes .. ).
> When I install python included in Centos repositories (2.7), the configure
> phase just passes without errors ..
> Any clues?
> Thanks,
> Kobe
> Zoo-discuss mailing list
> Zoo-discuss at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20200205/aff1ffaf/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20200205/aff1ffaf/attachment-0001.png>
More information about the Zoo-discuss mailing list
