[ZOO-PSC] Call for vote: ZOO-Project 1.6.0 release
Angelos Tzotsos tzotsos at gmail.com
Wed Jan 11 06:24:00 PST 2017
Dear all, happy new year.
+1 for the 1.6.0 release,
Just a minor comment: a Release Candidate would help getting packages
done in time for the final release and build process tested on various
platforms (at least for the Linux packages I maintain).
Cheers,
Angelos
On 01/11/2017 03:55 PM, Fenoy Gerald wrote:
> Dear PSC members,
> first of all I wish you all a happy and fruitful 2017 year!
> I wish also the same to the project itself :)
> To start well with this new year, I would like to request you for a vote on releasing the 1.6.0 version.
> We have made various improvements in different places over the past year and it is more than time to release all that changes, sorry for not being able to handle this release earlier last year as it should be. Here is an overview of modifications made in the 1.6.0-dev (current trunk) version:
>    * Add the C# as a supported programming language for Services
>    * Add nested inputs and outputs support (WPS 2.0.0)
>    * Add servicePath special key to specify the service location
>    * Add --with-etc-dir option to specify the location of the main.cfg file
>    * Support GDAL version 2.1.0.
>    * Add the MapServer 7.0.1 internal support.
>    * Support for exotic location of openssl.
>    * Add ZOO-Client API documentation reference in the official documentation.
>    * Add CORS support.
>    * Fix issue when dealing with Array in JavaScript support.
>    * Update the Centos installation procedure.
>    * Small fixes in java support.
>    * Fix issue when XML request contains empty nodes for inputs
>    * Add status update for contour lines computation
>    * Fix FASTCGI location using the --with-fastcgi option.
>    * Redefined the API function addToMapWithSize to fix problem with Python/PHP support.
> I hope to have your vote soon for being able to proceed.
> Obviously I am +1 for this release to happen.
> Best regards,
> GĂ©rald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
> Zoo-psc mailing list
> Zoo-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-psc
Angelos Tzotsos, PhD
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Zoo-psc mailing list
