[ZOO-PSC] Call for vote: ZOO-Project 1.6.0 release
Daniel Kastl daniel at georepublic.de
Thu Jan 12 16:27:40 PST 2017
+1
On 11 Jan 2017 10:55 p.m., "Fenoy Gerald" <gerald.fenoy at geolabs.fr> wrote:
> Dear PSC members,
> first of all I wish you all a happy and fruitful 2017 year!
> I wish also the same to the project itself :)
> To start well with this new year, I would like to request you for a vote
> on releasing the 1.6.0 version.
> We have made various improvements in different places over the past year
> and it is more than time to release all that changes, sorry for not being
> able to handle this release earlier last year as it should be. Here is an
> overview of modifications made in the 1.6.0-dev (current trunk) version:
>   * Add the C# as a supported programming language for Services
>   * Add nested inputs and outputs support (WPS 2.0.0)
>   * Add servicePath special key to specify the service location
>   * Add --with-etc-dir option to specify the location of the main.cfg file
>   * Support GDAL version 2.1.0.
>   * Add the MapServer 7.0.1 internal support.
>   * Support for exotic location of openssl.
>   * Add ZOO-Client API documentation reference in the official
> documentation.
>   * Add CORS support.
>   * Fix issue when dealing with Array in JavaScript support.
>   * Update the Centos installation procedure.
>   * Small fixes in java support.
>   * Fix issue when XML request contains empty nodes for inputs
>   * Add status update for contour lines computation
>   * Fix FASTCGI location using the --with-fastcgi option.
>   * Redefined the API function addToMapWithSize to fix problem with
> Python/PHP support.
> I hope to have your vote soon for being able to proceed.
> Obviously I am +1 for this release to happen.
> Best regards,
> GĂ©rald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
> Zoo-psc mailing list
> Zoo-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/zoo-psc
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20170113/7749d5a1/attachment.html>
More information about the Zoo-psc mailing list
