[ZOO-PSC] R: ZOO-Project 1.7.0 release
Maria Antonia Brovelli
maria.brovelli at polimi.it
Fri May 31 11:21:01 PDT 2019
Thanks Gerald!!!
+1!!!
Maria
http://cci.esa.int/HRLandcover
Prof. Maria Antonia Brovelli
Professor of GIS and Digital Mapping
Politecnico di Milano
P.zza Leonardo da Vinci, 32 - Building 3 - 20133 Milano (Italy)
Tel. +39-02-23996242 - Mob. +39-328-0023867, <mailto:maria.brovelli at polimi.it> maria.brovelli at polimi.it
https://orcid.org/0000-0003-3161-556
Da: Zoo-psc <zoo-psc-bounces at lists.osgeo.org> per conto di Gérald Fenoy <gerald.fenoy at geolabs.fr>
Inviato: venerdì 31 maggio 2019 17:33
A: zoo-psc
Oggetto: [ZOO-PSC] ZOO-Project 1.7.0 release
Dear PSC members,
I would like to ask you to vote for releasing 1.7.0 version of the ZOO-Project.
I suppose you have noticed the modifications that has been done over the past few months. One the biggest was to merge prototype-v0 in trunk [1] which was used during almost 2 years for developing the new ZOO-Project version, including for example the R support and the HPC one. Lately, we have made some tests for building for both GNU/Linux [2] and Window [3] platforms using appVeyor free account.
Bellow, you can see a list of important modifications:
* Fix issue with UOM definitions in zcfg2sql
* Make callback and HPC support independent from each other
* Update SAGA-GIS support to version 7.2.0
* Add support for custom MapServer style definition for raster output
* Fix returned bbox definition #170
* Store semaphore status in lenv section for future deletion
* Update Windows support to newer compiler
* Fix issue with UpdateStatus function from the Mono ZOO-API
* Add logging functionality and other utility functions to the C-API
* Return an exception for every output for which nb_pixel or
nb_features is 0
* Add a shared key to the security section to differentiate the
referenced data
* Add MapServer output style definition depending on the geometry
type
* Add ogr.tindex service
* Add support for literaldata input arrays and to call services
asyncrhonously from the JavaScript ZOO-API
* Expose a sleep function to the JavaScript ZOO-API
* Provide FinalizeHPC and FinalizeHPC1 services using scontrol and
sacct respectively
* Store md5sum of the cached file (so, local to the WPS server) to
compare before uploading (if different md5sum) on the HPC server
* Add support for R language
* Add support for using "file://" for referenced data input
* Add an optional ecookie key for returning third-party cookies
* Fix issue when parsing BoundingBox input #163
* Add memory key to the main section to force the ZOO-Kernel to load
data into memory or use local file
* Add the dialect input to the ogr2ogr service
* Store the list of generated mapfiles in a file (cf DeleteData service)
* Define the correct MS_IMAGEMODE in the generated mapfile
* Option to use MapServer support to publish heatmap
* Add status_code key to the lenv for setting Status HTTP response header
* Add the Creation Option inputs to the Gdal_Dem service
* Add prohibited key in the callback section to define a list of
services not requiring any invocation
* Produce zcfg for OTB applications using the correct default pixel type
* Add asynchronous callback invocation to send information about
the ongoing services to a third-party software
* Add mapsToJson, mapsToJson, and elementsToJson to the API
* Provide a zcfg2sql tool to convert a zcfg metadata file to SQL script
* Add support to store service metadata information into a database
* Add HPC Support for remote execution of SBATCH scripts through Slurm
* Add cookie reference to _HINTERNET
* Support headers for GET requests from the js ZOO-API
* Pass all headers listed in the attributes parameter from the
[security] section to the hosts listed in the hosts parameter of the
same section (ticket #139)
I am proposing myself as a release manager and the release to occur on next Friday (2019/06/07).
My vote is obviously +1 for this release.
Best regards,
[1] http://www.zoo-project.org/trac/changeset/917
[2] https://ci.appveyor.com/project/djay/trunk-t67ri/builds/24881108
[3] https://ci.appveyor.com/project/djay/trunk-hp3tw/builds/24868734
Gérald Fenoy
Gerald Fenoy
GEOLABS
Siège social :
Futur Building I
1280, avenue des Platanes
34970 Lattes
Tél. fixe : +33 (0) 4 67 43 09 95
Tél. portable : +33 (0) 6 70 08 25 39
Zoo-psc mailing list
Zoo-psc at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/zoo-psc
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20190531/7e5ffa66/attachment.html>
More information about the Zoo-psc
