[ZOO-PSC] ZOO-Project 2.0.0 release
Gérald Fenoy gerald.fenoy at geolabs.fr
Tue Feb 20 02:14:16 PST 2024
Dear PSC members,
Thanks for your vote that made the motion pass.
On Saturday, 17th February, we published the following release candidate 1: [1], a new DOI associated with the release has been generated automatically.
Also, I have started the process for the OGC certification. We are a bit late in the process as the deadline is today, and I only submitted the OGC Compliance yesterday.
If the ETS has been run for the OGC API - Processes - Part 1: Core successfully, I tried the WPS 2.0, but it failed in three tests. As the WPS 2.0 certification was gained on March 9th, 2023, we probably have more time to apply for this compliance, but I am unsure.
I will let you know how it goes, and we can learn from this experience to enhance in the coming year.
Best regards
[1] https://github.com/ZOO-Project/ZOO-Project/releases/tag/rel-2.0.0-rc1
Gerald Fenoy
Chair, ZOO-Project PSC
> Le 14 févr. 2024 à 10:45, Fabrice Brito <fabrice.brito at terradue.com> a écrit :
> +1
> On Tue, 13 Feb 2024 at 18:08, Gérald Fenoy via ZOO-PSC <zoo-psc at lists.osgeo.org <mailto:zoo-psc at lists.osgeo.org>> wrote:
>> Dear PSC members,
>> I intend to request your support in voting to release the ZOO-Project's 2.0.0 release candidate version.
>> There were some years since the last release.
>> Also, we need to renew the OGC-certified compliance license(s) for the ZOO-Project product on February 19.
>> So, I think it is perfect timing to release a new version and get it certified.
>> We tested on a local setup and the ZOO-Project passed 100% of the tests for both OGC API - Processes - Part 1: Core and synchronous WPS 2.0.
>> Below, you can see a list of significant modifications:
>>   * Update relation type to monitor for the status location.
>>   * Add support for the conformance class remote processes from the
>>   OGC API - Processes - Part 3: Workflow & chaining. Execution of
>>   remote processes are automatically run asynchronously in case the
>>   root process was invoked asynchronously.
>>   * Parse the Location header from ulinet and the cookie if any.
>>   * Add schemas to the components and support description stored in the file.
>>   * Add a trivial DeployOnHpc service for automating the installation
>>   and the deployment of a singularity container using the image
>>   parameter provided in the executionUnit used when deploying the
>>   process.
>>   * Set the key json_response_object with the JSON response that the
>>   ZOO-Kernel produced for the request, it can be updated from a
>>   filter_out process.
>>   * Update filter_in to support returning a response directly by
>>   adding a response key in the lenv section (binary is supported for
>>   this response)
>>   * Provide an initial Dockefile dedicated to the DRU support with
>>   remote HPC execution support
>>   * Add a USE_HPC_NESTEDOUTPUTS build option to activate the nested
>>   inputs and outputs addition (not supported with OGC API - Processes
>>   - Part 1: Core)
>>   * Update C-API errorException and printExceptionResponse* signatures
>>   to handle the main configuration maps memory properly
>>   *  Build Docker image with DRU supporting OpenEO UDP encoding
>>   * Add support for deploying and executing OpenEO User Defined
>>   Processes by using an OpenEO graph for the executionUnit
>>   * Add support for schema type string for request body, providing a
>>   way to include CWL example files in the published OpenAPI
>>   * Integrate the OGC API - Processes - Part 2: Deploy, Replace,
>>   Undeploy optional support.
>>   * Build Docker image based on MDL4EO/OTBTF and the onnx runtime for
>>   models sharing
>>   * Integrate the TeamEngine and ETS for OGC API - Processes
>>   * Add JWT parser in security_service.py as filter_in to allocate
>>   resources per authenticated user
>>   * Integrate the work done during GSoC 2022 to support Node.js
>>   ZOO-Services (cf. updated documentation for NodeJS)
>>   * Update support to filter the jobs list using the user_id
>>   * Add support for nested processes n OGC API - Processes - Part 3:
>>   Workflows & Chaining
>>   * Add filter_in and filter_out service array to be invoked previously
>>   of and after the service run
>>   * Add trivial support for OpenAPI security, basicAuth / openId, and add
>>   sample services implementation
>>   * Add support for MapServer 8.0 (actually 7.7-dev), including
>>   returning result as OGC API -Features
>>   * Integrate downloading MapServer 8.0 and building from the
>>   dedicated Dockerfile-MS8
>>   * Include basicAuth build instructions in the Dockefile
>>   * Add basicAuth service illustrating how to secure access to OGC API
>>   - Processes using Basic Authentication
>>   * Use the osecurity section to detect secured path, request method
>>   from the published OpenAPI
>>   * Update the printHeaders function to allow Status definition at runtime
>>   * Add a [osecurity] section to secure access to path, method couple
>>   * Update the database connection handling to make it independent from
>>   instantiation order
>>   * Use the RabbitMQ also for OGC API - Processes
>>   * Pass the subscriber if any is passed from the original request
>>   * Make C OGR base-vect-ops compatible with memory=protect
>>   * Add volumes to be shared by the ZOO-Kernel and the ZOO-FPM
>>   * Add a RabbitMQ and a ZOO-FPM container to docker-compose
>>   * Add documentation for RabbitMQ support and ZOO Fast Process
>>   Manager (ZOO-FPM)
>>   * Optional use of ZOO-Kernel Fast Process Manager backends to handle
>>   asynchronous execution
>>   * Partial integration of the code from the
>>   Publicamundi_David_integration01-devel branch
>> I propose myself as a release manager, and the release is to occur this coming Saturday (2024/02/17).
>> My vote is +1 for this release to happen as proposed.
>> Best regards,
>> Gerald Fenoy
>> gerald.fenoy at geolabs.fr <mailto:gerald.fenoy at geolabs.fr>
>> ZOO-PSC mailing list
>> ZOO-PSC at lists.osgeo.org <mailto:ZOO-PSC at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/zoo-psc
> Fabrice Brito
> @terradue
> Roma, Italia
> http://www.terradue.com <http://www.terradue.com/>
> https://twitter.com/terradue
> m +39 3406767340
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20240220/0a4ac224/attachment.htm>
More information about the ZOO-PSC mailing list
