[ZOO-PSC] ZOO-Project version 2.0.0 has been released
Gérald Fenoy gerald.fenoy at geolabs.fr
Sat Mar 2 08:20:17 PST 2024
Dear community,
as the release manager, I am happy to announce that the release of the ZOO-Project version 2.0.0 is available online [1].
Thanks everyone for your contributions to the project and its enhancement!
If you'd like to cite this release in your research article, refer to the DOI associated with the release [2].
This new release contains new features and fixes listed below.
  * Update the remote process support to enable multi-valued processes.
  * Add option to output log on stderr rather than a dedicated file.
  * Update relation type to monitor for the status location.
  * Add support for the conformance class remote processes from the
  OGC API - Processes - Part 3: Workflow & chaining. Execution of
  remote processes are automatically run asynchronously in case the
  root process was invoked asynchronously.
  * Parse the Location header from ulinet and the cookie if any.
  * Add schemas to the components and support description stored in the file.
  * Add a trivial DeployOnHpc service for automating the installation
  and the deployment of a singularity container using the image
  parameter provided in the executionUnit used when deploying the
  process.
  * Set the key json_response_object with the JSON response that the
  ZOO-Kernel produced for the request, it can be updated from a
  filter_out process.
  * Update filter_in to support returning a response directly by
  adding a response key in the lenv section (binary is supported for
  this response)
  * Provide an initial Dockefile dedicated to the DRU support with
  remote HPC execution support
  * Add a USE_HPC_NESTEDOUTPUTS build option to activate the nested
  inputs and outputs addition (not supported with OGC API - Processes - Part 1: Core)
  * Update C-API errorException and printExceptionResponse* signatures
  to handle the main configuration maps memory properly
  *  Build Docker image with DRU supporting OpenEO UDP encoding
  * Add support for deploying and executing OpenEO User Defined
  Processes by using an OpenEO graph for the executionUnit
  * Add support for schema type string for request body, providing a
  way to include CWL example files in the published OpenAPI
  * Integrate the OGC API - Processes - Part 2: Deploy, Replace,
  Undeploy optional support.
  * Build Docker image based on MDL4EO/OTBTF and the onnx runtime for
  models sharing
  * Integrate the TeamEngine and ETS for OGC API - Processes
  * Add JWT parser in security_service.py as filter_in to allocate
  resources per authenticated user
  * Integrate the work done during GSoC 2022 to support Node.js
  ZOO-Services (cf. updated documentation for NodeJS)
  * Update support to filter the jobs list using the user_id
  * Add support for nested processes n OGC API - Processes - Part 3:
  Workflows & Chaining
  * Add filter_in and filter_out service array to be invoked previously
  of and after the service run
  * Add trivial support for OpenAPI security, basicAuth / openId, and add
  sample services implementation
  * Add support for MapServer 8.0 (actually 7.7-dev), including
  returning result as OGC API -Features
  * Integrate downloading MapServer 8.0 and building from the
  dedicated Dockerfile-MS8
  * Include basicAuth build instructions in the Dockefile
  * Add basicAuth service illustrating how to secure access to OGC API - Processes using Basic Authentication
  * Use the osecurity section to detect secured path, request method
  from the published OpenAPI
  * Update the printHeaders function to allow Status definition at runtime
  * Add a [osecurity] section to secure access to path, method couple
  * Update the database connection handling to make it independent from
  instantiation order
  * Use the RabbitMQ also for OGC API - Processes
  * Pass the subscriber if any is passed from the original request
  * Make C OGR base-vect-ops compatible with memory=protect
  * Add volumes to be shared by the ZOO-Kernel and the ZOO-FPM
  * Add a RabbitMQ and a ZOO-FPM container to docker-compose
  * Add documentation for RabbitMQ support and ZOO Fast Process
  Manager (ZOO-FPM)
  * Optional use of ZOO-Kernel Fast Process Manager backends to handle
  asynchronous execution
  * Partial integration of the code from the
  Publicamundi_David_integration01-devel branch
We appreciate and welcome any feedback.
Best regards,
[1] https://github.com/ZOO-Project/ZOO-Project/releases/tag/rel-2.0.0
[2] https://zenodo.org/badge/latestdoi/353351321
Gerald Fenoy
Chair, ZOO-Project PSC
URL: <http://lists.osgeo.org/pipermail/zoo-psc/attachments/20240302/81f481c7/attachment.htm>
More information about the ZOO-PSC mailing list
