[Aust-NZ] Fw: Entire USGS Landsat Archive at No Charge.
Bruce.Bannerman at dpi.vic.gov.au
Thu Apr 24 01:47:07 EDT 2008
IMO:
fyi in case you missed this:
Source info at:
http://landsat.usgs.gov/images/squares/USGS_Landsat_Imagery_Release.pdf
Bruce Bannerman
----- Forwarded by Bruce Bannerman/DPI/VICGOV1 on 24/04/2008 03:42 PM
jo at frot.org
Sent by: geodata-bounces at lists.osgeo.org
24/04/2008 05:01 AM
To
geodata at lists.osgeo.org
cc
pedro.goncalves at terradue.com
Subject
[Geodata] Fw: [Spanish] Landsat 7 liberado
"The full archive of historical Landsat 7 ETM+ data acquired by
the USGS since launch in 1999 will become available for
selection and downloading by the end of September 2008.
By the end of December of 2008, both incoming Landsat 5 Thematic
Mapper (TM) data and all Landsat 5 TM data acquired by the USGS since
launch (1984) will become available, with all Landsat 4 TM (1982-1985)
and Landsat 1-5 Multi-Spectral Scanner (MSS) (1972-1994) data becoming
available by the end of January 2009. All Landsat data purchasing
options from the USGS will be discontinued by February 2009"
----- Forwarded message from Agustin Diez Castillo <adiez at uv.es> -----
Parece que van a liberar Landsat 7 en Julio y todo los historicos antes
de
febrero de 2009
http://www.public.asu.edu/~cmbarton/files/info/USGS_landsat_release.pdf
Geodata mailing list
Geodata at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geodata
Notice:
This email and any attachments may contain information that is personal,
confidential, legally privileged and/or copyright.No part of it should be reproduced,
adapted or communicated without the prior written consent of the copyright owner.
It is the responsibility of the recipient to check for and remove viruses.
If you have received this email in error, please notify the sender by return email, delete
it from your system and destroy any copies. You are not authorised to use, communicate or rely on the information
contained in this email.
Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20080424/267a5db0/attachment.html
More information about the Aust-NZ
