[Aust-NZ] Inquiry into Improving Access to Victorian Public Sector
Information and Data
Bruce.Bannerman at dpi.vic.gov.au
Sun Aug 10 23:07:02 EDT 2008
IMO:
Cameron,
I have given this some thought over the last few days, particularly after
reading through the Inquiry's discussion paper.
There are significant spatial issues that need to be addressed in their
own right.
Therefore, I think that it would be appropriate to address this under a
separate submission, that was focussed mainly on spatial.
As an OSIA list member, I'm happy to share what I come up with, if there
is interest.
Regards,
Bruce Bannerman
Cameron Shorter <cameron.shorter at gmail.com> wrote on 07/08/2008 02:44:35
PM:
> Introductions:
> Open Source Industry Australia (OSIA) meet
> the Australian/New Zealand chapter of the Open Source Geospatial
> Foundation (OSGeo).
> (and visa-versa)
> As I understand it, individuals from both email lists are planning to
> write a response for this Public Access to Data Proposal and I suspect
> all responses will have a similar message.
> In particular, interest has been shown from:
> Brendan Scott, Adam Crow from OSIA
> Bruce Bannerman, Bruce Bannerman, and maybe Rob Atkinson from OSGeo
Aust/NZ.
> I suggest consider writing a polished joint submission which should be
> better as it has more inputs and reviewers.
Notice:
This email and any attachments may contain information that is personal,
confidential, legally privileged and/or copyright.No part of it should be reproduced,
adapted or communicated without the prior written consent of the copyright owner.
It is the responsibility of the recipient to check for and remove viruses.
If you have received this email in error, please notify the sender by return email, delete
it from your system and destroy any copies. You are not authorised to use, communicate or rely on the information
contained in this email.
Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/aust-nz/attachments/20080811/6875ef41/attachment.html
More information about the Aust-NZ
